-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Spring Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-spring-projects.html)
kyoo Nov 3, 2021 11:09 AM
Originally Posted by Dallas J (Post 11943823)
You can as long as you have injector scaling approximately for your ethanol percentage. Being off 15% either way from what you're dialed in for is no problem but you wouldnt want to go from E85 to like E40 without adjusting.
ok - maybe better if i just try to burn to nothing and fill up as much as possible with pump premium then. im getting tuned on 91 soon which is why i was trying to do a little to burn off before i fully fill it with 91, since 1-1.5 gal of e85 would basically (i think) make 91 basically 93
(it is a dual map tune between pump & e85)
Biggiesacks Nov 3, 2021 11:47 AM
I'm sure you're going to a good tuner, so you shouldn't worry about it. Realistically, if your going back and forth between fuels that scenario will happen, and your tune should have enough margin in it to deal with that. If your OCD is getting the better of you though, you can drain the tank from underneath. You could also disconnect a line from the rail (which ever is easier) and either run the pump with evoscan, or jump/trigger a fuel pump relay with a piece of wire. I don't know how stock or not your setup is, but it's pretty easy to get a hose on the return line from the fuel rail and into a container. Remember to have a fire extinguisher at the ready when ever dealing with fuel.
kyoo Nov 3, 2021 12:26 PM
yup i've drained from the return line in the past - anyway i've done it the old fashioned way driving around - dont really have time with my new job these days but had a little of time during and and can do the rest tonight
Ayoustin Nov 3, 2021 12:34 PM
There are drain plugs on the bottom of the tank too. One on each half, directly on the bottom.
ViciousLSD Nov 3, 2021 12:55 PM
I put fittings on those drain plugs, so i can move the gas to another car :)
Biggiesacks Nov 3, 2021 01:03 PM
Good Idea, especially considering we seem to be in the mad max timeline.
Biggiesacks Nov 3, 2021 01:08 PM
Driving around is probably a lot safer than handling fuel, and storing it.
LetsGetThisDone Nov 6, 2021 10:57 AM
Do any of you know anyone in Nashville, TN that could flash an EvoX for me? Have a client that moved their that needs a tune update. I sent him an openport cable, but he apparently only has a Mac laptop...
Bee-Raddd Nov 6, 2021 12:42 PM
just drain it, either from the tank or run the pump and pump it out then fill up with fresh fuel. Its pretty straight forward either way. just do it when the engine is cold if you do it from the return line. doing it from the tank is fine also. youd have to do something pretty silly for it to catch fire when draining from the tank. just dont do it when the car is warm/hot
LetsGetThisDone Nov 6, 2021 11:12 PM
Yeah, but it's Kyoo we're talking about here.
kyoo Nov 16, 2021 05:24 PM
lmao hey! i have actually done this (1/4" line for anyone curious) but not ideal.
in any case -
if I feel like I have too much power-on oversteer, is there anything I can do to improve that without making the car understeer more? all the conventional solutions (fsb/ less rear spring) seem like it would come at the cost of being pushier
kaj Nov 16, 2021 05:25 PM
in any case -
I modulate my throttle.
kyoo Nov 16, 2021 05:30 PM
boo
EVO8LTW Nov 16, 2021 06:15 PM
Wider and/or stickier tires, less steering angle, less focus on "getting to WOT ASAP on corner exit" and more focus on maintaining mid-corner speed, use higher gear, make sure WGDC is proportional to throttle position in tune, have someone in the right seat watch you when this happens, etc.
Dallas J Nov 16, 2021 06:21 PM
Have I told you about my lord and savior, More Rear Spring? :lol:
