Originally Posted by kyoo
(Post 11944494)
roll center kit not enough, imagine the front upright should improve that though? plus i will tweak the ride heights for front and rear sometime, it's the off season already here
understood.
So I'm looking at battery boxes now to cover the battery inside the trunk, something like this: Looks like I can use the brackets I have to secure the box itself down, but how do you secure the battery inside the box if the size isn't a perfect fit? |
Switch to Gravel/Snow :)
(Post 11944501)
https://www.amazon.com/NOCO-HM300BKS...dp/B004W5SFYW/ Looks like I can use the brackets I have to secure the box itself down, but how do you secure the battery inside the box if the size isn't a perfect fit? |
(Post 11944504)
Is the box required when putting the batt in the trunk? you've inspired me to start working on this
(Post 11944506)
not required tray would be simplest but box would be cleaner. probably just gonna do the tray
Any close up pics of the acd line connectors needed to move it to the trunk? i keep searching but pics are not showing. Maybe you can document in your build page :) Do i need these here? https://www.ebay.com/itm/36338731933...AAAOSwX9dglRDS |
(Post 11944513)
cool thanks. maybe i'll make it look like a subwoofer, This could be the 1st time I'm drilling holes on this car lol
Any close up pics of the acd line connectors needed to move it to the trunk? i keep searching but pics are not showing. Maybe you can document in your build page :) Do i need these here? https://www.ebay.com/itm/36338731933...AAAOSwX9dglRDS Out of curiousity do you guys have the mount holes and everything in the left rear wheel well for mounting the pump in its JDM location? |
Originally Posted by bee-raddd
(Post 11944551)
You would need lines to run to the rear of the car. Wonder if you could order the hard lines direct from mitsubishi? The ACD runs along next to the brake lines down the left side of the floor. and the ones to the AYC run from the pump down to the diff.
(Post 11944513)
(Post 11944457)
that is what i was getting at but I'm gonna check my alignment/maybe add some toe in in the rear because i otherwise like how the car behaves.
picked up me Evo today. leak was an oil fitting (not sure which) and they also resealed the oil pan. here's a pic of the acd and battery relocation. i wanted the whole acd pump in the trunk for reliability https://cimg5.ibsrv.net/gimg/www.evo...b0fbc0b008.jpg Did you pay for this work or was it DIY? |
(Post 11944560)
(Post 11944561)
haha i paid quite a bit for the work.
Do you guys remember this pump relocation? (one of the best for sure)
https://cimg1.ibsrv.net/gimg/www.evo...a4e8ed091b.jpg https://cimg5.ibsrv.net/gimg/www.evo...792d1dac18.jpg |
(Post 11944561)
(Post 11944563)
| All times are GMT -7. The time now is 06:20 PM. |
