-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Spring Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-spring-projects.html)
ViciousLSD Nov 24, 2021 02:07 PM
Originally Posted by kyoo (Post 11944648)
if you guys thought i was not good at mechanical stuff, i am double-y backwards when electric stuff is involved.
i can, however, go on swaps and debt capital markets... lmao
No biggie. I got a degree in Electronics but they never covered automotive stuff lol
kyoo Nov 29, 2021 07:10 AM
i just received the fuse - do I screw this under the positive terminal adapter? or the actual wingnut, i guess as you mentioned. no additional nut came with it so I'll need to find something that attaches to the stud on this guy.
Bee-Raddd Nov 29, 2021 09:35 AM
Replace the wing nut with a regular nut and bolt and screw to the fuse. In your picture there is the original fuse block see if theres a nut on there. It will be a standard m6 nut i assume anyway. The battery post piece will be M8.
ViciousLSD Nov 29, 2021 09:47 AM
googled pic
https://cimg7.ibsrv.net/gimg/www.evo...f3baac5e93.jpg
probably an m8 nut but your battery clamp looks like SAE. you can use the wing nut if you can tighten it. move your red cable to the "blue post" with higher amperage rating. these could be m6
kyoo Nov 30, 2021 08:06 AM
This is what I received, and what's currently installed. I can mount the fuse to the terminal using the wingnut, but how do i mount the cable to the fuse? The cable seems a little too big for the fuse's stud, if that's what I am to do.
https://cimg2.ibsrv.net/gimg/www.evo...b070a6624c.jpg
https://cimg8.ibsrv.net/gimg/www.evo...5e999e02c5.jpg
ViciousLSD Nov 30, 2021 08:37 AM
That's all there is to it. you can add steel washers to increase the contact surface if you want
kyoo Nov 30, 2021 08:50 AM
ahh - you mean connect the fuse stud to the terminal mount, and the red cable to the flat, circular part on the fuse?
ViciousLSD Nov 30, 2021 09:21 AM
well no, but it will work in either direction (if you can actually install it backwards). I thought you said the cable terminal is too big... some washers can be used to sandwich the terminal, if I understand your concern
kyoo Nov 30, 2021 09:50 AM
the red cable's copper connector is 2cm wide, vs opening for the fuse's stud being 1.3cm wide - so you're saying stack washers until it reaches a height that the connector can just sit on top of the washers?
Bee-Raddd Nov 30, 2021 09:57 AM
Connect 1 to 1 and 2 to 2. If the terminal lug hole is too big i wouldnt worry about it just put a washer on either side of the terminal lug before you screw it down. when your free swing by an auto sparky and ask them to crimp a new lug on thats the right size will cost ya $5 and 5min of their time.
https://cimg2.ibsrv.net/gimg/www.evo...1946d22c9d.jpg
https://cimg3.ibsrv.net/gimg/www.evo...e1e376ef31.jpg
kyoo Nov 30, 2021 10:06 AM
This is what I mean - thanks for the pic - (1) on the fuse is too small for (1) on the cable (i realize I took a pic of the negative terminal, pos and neg are the same size). it physically won't fit.
https://cimg8.ibsrv.net/gimg/www.evo...fc5ef2a604.jpg
https://cimg0.ibsrv.net/gimg/www.evo...9f709a2ba9.jpg
ViciousLSD Nov 30, 2021 10:11 AM
:lol:
I would probably use this for my batt reloc, I just like corners
https://www.lowes.com/pd/Southwire-L...B&gclsrc=aw.ds
ViciousLSD Nov 30, 2021 10:13 AM
you can trim the plastic to the right of the stud (in that pic) OR trim the copper terminal. I get your stacking washers idea. that works too
kyoo Nov 30, 2021 10:37 AM
i was kind of leaning towards trimming the black plastic with a dremel or something actually, so that should work! thanks
Balrok Nov 30, 2021 10:54 AM
I actually skip all of that battery top parts due to the "little things" that come with it. Back when I was building the cage and doing this relocation in a pinch we got this from best buy:
https://rockfordfosgate.com/products/details/rffdagu/
It's a topic of conversation at every track day when people look in the engine bay and see this "sound system piece" lol where all of the positive connections come in (old front battery location).
