Originally Posted by griceiv
(Post 11950186)
i still don't get the irrational obsession with droop travel. if you want more droop travel run softer springs. the stock springs have a **** load of droop travel
Originally Posted by kyoo
(Post 11950191)
yea, it's at a length overall now too where u cannot physically get the shock in there without dropping the arm, or, what i did, shorten the coilover, and then spin the threads out taller while it was in the strut top area until it reached the top.
i always have to unbolt the control arm to remove/install the rear coilovers |
(Post 11950198)
arent you using a jack to lift the control arm a bit? you dont want that going too low where it max's out the top ball joint.
(Post 11950207)
im pushing it down to get the strut in and out
what happened to the helper spring? for me thats a 35mm-80mm spacer |
Sounds like you need to fit a shorter spring if you cant get the right height you want with the one fitted. keeper springs will fully depress as soon as the car sits on them so they dont do alot really apart from keep the spring captive.
That only holds true if you have a spring soft enough it has preload. Even at the moderate range of rates evos need theirs very little static compression (the spring compression seen just under normal stationary weight). And droop beyond spring fully unloaded is 100% pointless in terms of handling. And running a high preload tender to try and push the wheel further only serves to reduce roll rate.
The math doesn't work out and empirically several of use have tested both ways multiple times hunting for any clues to a better option. |
while it may be fair that droop travel is not all that important, i lost a ton with these uprights installed.
it is, pick up the inner wheel as soon as you turn, level of droop travel. is this intentional/part of the design? picture below of the rear wheel off the ground. https://cimg9.ibsrv.net/gimg/www.evo...f906b66565.jpg |
2" to fender at full droop is a ton of droop. What gap to fender are you trying to run? Even a 12k spring, static compression is in the 1.5-1.6" range so youd be left with .4-.5" to fender assuming you can tuck the tire (which you should be able to) is great. FWIW, on stock fenders I could tuck a 295.
But you can always flip the arm to change the range of travel by about .75" at the tire. |
Originally Posted by Dallas J
(Post 11950314)
But you can always flip the arm to change the range of travel by about .75" at the tire. if i run a 9" spring and preload an inch of it, is that essentially the same setup i have with a 8" spring with zero preload? also, it might help to start from an extreme case and elaborate from there. ire, why have any droop travel at all? keeping in mind these are limited aero street cars. |
lower collar (height) adjustment is the one that changes the overall length of the coilover.
have you looked to see is FA threaded tube fits Ohlins? these ssb uprights are for *extremely lowered* cars i believe |
(Post 11950320)
this is set at about 1" between the top of the tire and the bottom of the fender in the rear, so it's only drooped 1". not looking to tuck the tire, I'm running street friendly heights in front and rear. what other options would i have to increase the travel by ~1"? aside from a softer spring? more preload on the spring? I'm on a 13k spring at the moment.
if i run a 9" spring and preload an inch of it, is that essentially the same setup i have with a 8" spring with zero preload? also, it might help to start from an extreme case and elaborate from there. ire, why have any droop travel at all? keeping in mind these are limited aero street cars. Spring length has no effect on travels, so if you preload a 9" spring you just need that X force before you get any travel. Evo rates do not lend themselves to preloading unless necessary for fixed length shocks. Youd just change spring length for perch location and travels. |
(Post 11950333)
have you looked to see is FA threaded tube fits Ohlins? these ssb uprights are for *extremely lowered* cars i believe The rear can be a challenge just from the travel stand point because by the nature of the the lower control arm being on the main member thats being altered, you change the shock stroke 0.9". The easy fix for Evos is to flip the lower control arm and ark up instead of ark down. It just needs to use a urethane bushing at the shock to keep the arm clocked and keeping the stock spherical ends. |
(Post 11950334)
Are you not understanding what I mean when I say flip the lower control arm? That will give you .75" more droop.
That just depends on what it lands you in travel range. I would still just set the main spring to exactly 0 preload and set ride with the body length after flipping the arms.
(Post 11950375)
| All times are GMT -7. The time now is 05:38 PM. |
