Originally Posted by LetsGetThisDone
(Post 11970508)
If you disconnect a line on a charged AC system it makes a ****ing mess. Guarantee they didn't do that.
They either evac'ed the system (for no reason, the work you had done didn't require it), or your AC had been non-op already and you didn't know. |
Does anyone happen to know the weight of an empty TC housing? I'm looking at the magnus billet option for some additional weight saving but its crazy money. Trying to figure out if it is even lighter.
Thanks! |
Originally Posted by leetEVO
(Post 11970517)
Thanks! |
(Post 11970517)
Thanks! Theres cheaper options to save mega weight. Carbon doors knock 60kg off stock doors. Tubular rear subframes take off 30kg |
I have this stupid looking cam. is this damaged or a manufacturing defect?
https://cimg2.ibsrv.net/gimg/www.evo...0f9fc56e23.jpg |
Yeah, I would say the cam and probably rocker are both bad. The rocker had to have caused it though Ive never seen it happen before.
Isn't it weird it didn't damage to lobe where there's more pressure?
Kinda but maybe there was enough load at that point the roller was forced to turn and it was low enough at the flat to skip/rub
How long have the cams been in the car for? Could be a number of things. Make sure the roller on the rocker arm is good and the lifter compresses properly before you reach out to them though as they will immediately question that.
maybe 9 years/15k miles old. I'm not going to chase the manufacturer.
I'm about to replace the lifters tonight and see whats up |
Originally Posted by Bee-Raddd
(Post 11970522)
I have been told that they are heavier. Stronger but heavier.
Thats the rocker not wanting to spin. Time for all new rockers and lifters along with the new cams.
There was no tension on the rocker, but the roller does work fine. I dont see any damage to the rocker.
I did replace the lifters today (Topline) and now have tension on that rocker. Test run tomorrow. I hope that was the cause of the new rattle that caused me to drop from an anticipated autox event. not a spun bearing or something else Q: Does anyone sell the 2.2l 94mm crank shortblock (i have no core to send)? |
(Post 11970600)
I did replace the lifters today (Topline) and now have tension on that rocker. Test run tomorrow. I hope that was the cause of the new rattle that caused me to drop from an anticipated autox event. not a spun bearing or something else Q: Does anyone sell the 2.2l 94mm crank shortblock (i have no core to send)? You should replace the whole assembly under that cam lobe to be safe. rocker, roller the whole lot. and youll probably have metal in your oil and filters although the failure doesnt seem massive, should do an oil change to be safe if you havent already |
(Post 11970618)
Buschurs seem to always have short blocks up for sale on their facebook maybe talk to them?
You should replace the whole assembly under that cam lobe to be safe. rocker, roller the whole lot. and youll probably have metal in your oil and filters although the failure doesnt seem massive, should do an oil change to be safe if you havent already I check my oil every time but not whats in the filter, never saw anything alarming. mostly copper dust from valve cover/baffles. I wonder if one of the tuner shops took another part from my car lol. if the roller is working then this was hammered from insufficient lift I'll get the camshafts and new set of rockers. thanks (Having the IE oil pan means more fresh oil to throw out lol) |
| All times are GMT -7. The time now is 08:53 PM. |
