-   Motor Sports (https://www.evolutionm.net/forums/motor-sports-15/)
-   -   Sup w/them 2026 Spring Projects? (https://www.evolutionm.net/forums/motor-sports/751735-sup-w-them-2026-spring-projects.html)
Kevin. Dec 6, 2023 08:58 AM
Originally Posted by Ayoustin (Post 11974879)
If you'd be willing to loan it to me for a couple weeks to measure up and then I can send it back that'd be awesome!
Originally Posted by kikiturbo (Post 11974899)
are you planing on doing the whole mount or just the bush insert? As the 6 spd mount is a big hunk of cast iron, unlike the 5 spd fabbed item...
Here's pics
https://cimg1.ibsrv.net/gimg/www.evo...b6f5e08149.jpg
https://cimg2.ibsrv.net/gimg/www.evo...a5657b8a79.jpg
PM the shipping address Austin and I'll send it out!
Ayoustin Dec 6, 2023 10:24 AM
It'll be a full replacement billet aluminum mount using the same bushings as the 5 speed mount. I'll likely get the design done and then we'll do them in small runs requiring an upfront payment like we're doing with the Evo 4/5/6 rear engine mount.
Originally Posted by Kevin. (Post 11974903)
Here's pics
Sent, thanks!
kyoo Dec 6, 2023 11:15 AM
sorry - what are the benefits of the mount? crisper shifts?
Ayoustin Dec 6, 2023 11:51 AM
Less wheel hop/better ability to put power to the ground due to reduced engine movement is the main one but yea shift feel is improved a bit as well as some weight reduction (around 4-5lbs dropped over the stock mounts).
kyoo Dec 6, 2023 02:30 PM
ah gotcha. i've never had the wheel hop issue thankfully, but i deal with pretty low grip (255, asphalt) situations
RSMike Dec 7, 2023 11:21 AM
I tried the Cusco mounts for Evo 4-6. The fitment was great, but it rendered by rear-view mirror almost useless.
2.3 with no balance shafts and semi-solid rear diff mounts made too much vibration for my liking!
I wonder if your material will be OK?
RSMike Dec 7, 2023 11:34 AM
Repacking Wheel Bearings
I chatted with a few colleagues about repacking "sealed" wheel bearings with motorsport grease. Yup it's definitely a thing.
Not only for performance but also for longevity.
I had some old front and rear wheel bearings here, so I pressed them apart and tested on them before doing my actual bearings. Passed!
When you press the hub flange out of the bearing, it takes the inner race with it. I think you'll only be able to do this on a few select bearings, it wont work with every car/model.
Apparently, Subaru STI Motorsport wheel bearings are just the normal bearings but with motorsport grade grease. So that makes sense.
https://cimg2.ibsrv.net/gimg/www.evo...3fffa4ec4b.jpg
https://cimg3.ibsrv.net/gimg/www.evo...057f108cf2.jpg
https://cimg4.ibsrv.net/gimg/www.evo...854cdd0af0.jpg
https://cimg6.ibsrv.net/gimg/www.evo...ee6724457b.jpg
https://cimg5.ibsrv.net/gimg/www.evo...2cbe691778.jpg
These are OEM genuine Evo 7-9 front wheel bearings. Only done around 3000-4000 miles and maybe 10-12 track days.
The lubricant hadn't gone completely solid, but it was looking like it was heading that way. The very old bearings I practiced on were bad, the grease was solid (20+ years old).
I found brake-cleaner was the best thing to dissolve the old wheel bearing grease. I tried acetone and it didn't really work.
Brake-cleaner and compressed air was the best way to get the grease off the plastic cages. You have to bend them to get them out of the bearing, so be careful.
Seems like it would be easy to tear a seal when you're getting them out.
Neo Synthetics HP800 is the best of the best motorsport grease, so that's gone into the bearings.
Lightly press everything back together for assembly. When you re-install the axle and hub nut, this will final compress everything to where it needs to be.
https://cimg1.ibsrv.net/gimg/www.evo...c7cd6478cd.jpg
https://cimg3.ibsrv.net/gimg/www.evo...fdb69d1747.jpg
https://cimg2.ibsrv.net/gimg/www.evo...171602f7cf.jpg
https://cimg9.ibsrv.net/gimg/www.evo...16b6c05fc2.jpg
How much grease is too much?
I'll pull these down and inspect next year and report back :)
Seems like a tub of Neo HP800 would go a really long way!
Dallas J Dec 7, 2023 11:42 AM
I wonder what the grade of balls used on the OEM bearing are. If it could be worthwhile getting a better ball while you're in there. Or even just swapping out the steel balls for ceramic with using factory race.
I should take one of the many bearings I have here apart and do some measuring.
RSMike Dec 9, 2023 09:41 PM
I measured them - they are 11.11mm in the fronts.
Could easily swap them out for ceramics. Pretty expensive project though!
Ayoustin Dec 10, 2023 08:17 AM
NVH ties heavily to bushing durometer. The Street bushings we offer (70-75A) are generally just a mild increase in NVH. Bushing location and orientation also plays a large part in how much NVH is transmitted to the chassis, which is why our CT9A rear mount uses 2 bushings like the factory mount. Without knowing how stiff the Cusco it's hard to say how they'll compare but I can say we don't get many complaints with our Street bushings on other platforms.
I have someone sending me a CP9A rear mount so we'll have all of the mounts covered for E4-9. The 4-6 rear mount and the 6 speed trans mount we'll likely only do in small runs and require a deposit.
RSMike Dec 10, 2023 11:45 AM
I know the Evo 4-6 and Evo 7-9 front mount is different, I think it's got a different height?
Construct Dec 10, 2023 11:56 AM
Out of curiosity I looked up the price of 7/16" ceramic balls. Took me a minute to realize that the listed price was for Qty=1 ball. Those things are expensive.
Construct Dec 10, 2023 12:01 PM
Got lucky on eBay and found a new old stock Amsoil air filter. These have been discontinued for years. Someone must have had one sitting on a shelf somewhere.
Interesting design with a second cone filter on the top. The improvement in airflow is probably minimal but I appreciate how they maximized the filtration area within the volume of the filter.
https://cimg0.ibsrv.net/gimg/www.evo...4a88a1e9a0.png
https://cimg1.ibsrv.net/gimg/www.evo...4a2576f88a.png
Ayoustin Dec 10, 2023 12:33 PM
From what I've been told they front mount is slightly different but still compatible. Will know for certain when I have someone to test fit though.
kyoo Dec 10, 2023 01:13 PM
yea that's the one i've been using for years, we discussed earlier. apparently they sold the line to injen, but i actually like the design of the afe one ( ) just as much anyway.
re: ceramic bearings, I dished out $$$ on pro bearing's ceramic bearings (ceramic bearings steel race) when I switched to Dallas's uprights, but to be honest i didn't notice a difference in using them.
https://www.facebook.com/ProBearing/photos/a.106575874505470/180931630403227/
