Originally Posted by deeman101
(Post 11907090)
Wow I'm more shocked to see the 6spd. Didn't realize they still survived this long in track evos. I remember my 6spd shifter was already taller than the 5spd but yours is definitely even higher. I'd still want to run the full console though. You think a smaller lift could be achieved with the console still intact? Or is there just no room.
Originally Posted by kaj
(Post 11907171)
I have a 5spd in the car now, since rebuilding a 6 is pretty much impossible without spending enough to buy a Civic :lol: I want to say the 5spd needed a bit of additional trimming, but I could be wrong. It wouldn't have been enough to make a difference, though. I raised my shifter exactly 3". Without going to the car to measure... maybe you could get away with 1.5-2" and still keep the cover in place....? Not sure the boot would fit, though.
(Post 11907222)
I'm gonna give it a try when my car goes back together. What did you say you used for the spacers? Stack of fender washers or something like that?
After spending an extraordinate ammount of time restoring a friends evo 9, finally got around to start work on my car..
sandblasted and painted the block, it is off to machine shop next week for 86 mm bore https://cimg1.ibsrv.net/gimg/www.evo...c5ceb1f99b.jpg Blasted the diff carriers, those are getting some Ralliart bushes, and the extra set of knuckles. Those will get some extension welded on to raise the roll centre and correct the steering geo.. https://cimg6.ibsrv.net/gimg/www.evo...53a46f1d8e.jpg finishing up the dry sump oil tank design... This one will occupy the space where the ABS unit used to be.. https://cimg7.ibsrv.net/gimg/www.evo...26f7aaa065.png |
I like the roll of toilet paper on top of the tank for extra filtration ;)
Originally Posted by Balrok
(Post 11907551)
Please don't tell me you intend to run coolant through that and reclaim crank case vapors.
Austin, where did you get the fictional idea coolant would be run through the tank to reclaim crank case vapors?
Kikiturbo is far too capable to consider anything so "way out there"! He lives in Europe where even high-end rallycross 600-800bhp motors are built with nearly OEM clearances, and do not exhibit severe blow-by. |
Air-Oil separator is likely to negate the need for additional breather, simply use the top of the tank as integrated breather.
Originally Posted by ayoustin
(Post 11907567)
edited it: but i do intend to run a sealed engine... i.e. all the breathing will be done trough the scavenge pump... if possible |
Originally Posted by alpinaturbo
(Post 11907594)
(Post 11907594)
Kikiturbo is far too capable to consider anything so "way out there"! He lives in Europe where even high-end rallycross 600-800bhp motors are built with nearly OEM clearances, and do not exhibit severe blow-by. In the Subaru world air-oil separator means a sealed catch can with coolant run through it to keep crank case vapors from freezing and it drains the oil back into the pan. Whatever moron invented it should be drug outside and shot. After working at a shop that specializes in Subarus I've seen plenty of stupid stuff come through the door. |
Wow Austin, never heard of reclaiming of oil vapors in Subaru world, although I am rarely venturing there. I had a thing for GC8 Type - RA Version 5 and 6, and 22b, but I do prefer Evo at the end of the day.
Would like to see one of us get ahold of a evo6 chassis and do a 9 LHD drivetrain build with it. Racefab has most of the parts already. Would be wicked light and nimble. Even better get the engine mounted longitude style as a bolt in kit.
(Post 11907734)
Having said that I would love an evo 5 with e9 mechanicals... |
| All times are GMT -7. The time now is 11:18 PM. |
