Anarchy99s First Build Thread: 2.4 Long Rod w/ Foward Facing HTA 3794 (Tons of Pics)
Old Aug 31, 2011, 07:01 PM
Anarchy99's Avatar
New PICS in Post 2 and Video in Post 3 First initial dyno graph is on page 11
Mod List Updated:
TTP Built 2.4 Long Rod
Built 5 Speed Transmission w/ Evo 9 first and Evo 8 second-fifth
Forced Performance HTA 3794r
TTP Custom o2 and downpipe
FIC 2150cc for E85
Koyo Half Rad
Full Blown Twin Pump
Magnus Manifold
Boomba TB and Fuel Rail
Much more!
So being that this is my first build thread I will try to be as detailed as possible, hopefully I do not leave anything out but please ask any questions you may have! As the build progresses I will update the thread
Why a 2.4 Long Rod? Well I wanted to try something new, I love torque and love the fact that I can spool quicker on the motor.
What Compression Ratio? I am going with a high compression 10.5.1 motor on E85. I think this combination will be ideal for a well-rounded powerhouse.
What Internals? We went with the Manley Turbo Tuff I-Beam Rods and Manley Pistons, the block was clearanced - Stock crank was balanced and polished with ARP Mains to bolt it all together
First things first - Here are some shots of the motor out of the machine shop:
The block was hand washed after bringing it back to the shop:
Engine Blood
Prepping with Bearings and Studs:
Apply Sauce:
Crank In:
Shot of the Pistons and Rods Pre-Install
Some Shots Before/After the Pins are Installed And Having Some Fun
Apply More Sauce and Connect
GO INTO YOUR HOLE!
Two Down
All In! (That's what she said)
Prior to the motor being done we went ahead and began making the water pump gasket here is the weld mod rather than spacer:
Modified Gasket:
Installed onto Front Case
Assembling Front Case
Putting Together Front Case and Timing Components
Install Mivec Oil Feed Line
Main Girdle, Getting Ready for Oil Pickup and Install
Install Rear Main Seal
Cleaning Oil Pan Bolts (Before)
Cleaning Oil Pan Bolts (After)
Oil Pain Prep & Install
ARP L19 Install
Power Enterprises Headgasket On and That's A Wrap! (For a few minutes)
Head Prep (Has Kelford 272's and Supertech Springs/Retainers)
Apply Copper Spray To Fill The Gaps
Install Head Gasket on Motor
Lord of the Rings! Then Head Installed!
Remove Crusty Cheap Oil Filter and Replace With Pretty Black One From Mitsu
These Cam Gears Look Boring - Let's Add Some Color!
Go Ahead and Toss on Alternator
The Water Pipe and Mivec Feed Line Needed To Be Modified
Nice Asses (Boomba.Magnus V5)
Old Aug 31, 2011, 07:02 PM
Anarchy99's Avatar
Magnus to Boomba Adaptor Plate
Boomba Installed
Boomba Fuel Rail Installed
Just In! FIC 2150cc Injectors and Installed
Took A Break In The Shop To Pull Condenser and Fan
Just In! Kiggly HLA and Installed
Priming The Motor
Timing Belt and Fluidampr Installed
Custom Bracket For Dipstick To Clear Magnus
Adjustable FPR and Osaka Coils Installed
Just For Fun Teaser Pics
Transmission Prep
Come to find out this crank was from an automatic! So Scott improvised and pull auto trans pilot
Install Clutch and Trans
Zeitronix 5 Bar Map Sensor and Koyo Half-Sized Radiator Installed
After Discussing our options to vent the motor we decided one method would be through the dipstick
Custom o2 - To Fit With 3794 and 2.4
While Car Was Running For The First Time
Putting some break-in miles on her
Old Aug 31, 2011, 07:04 PM
Anarchy99's Avatar
First Start Today!
http://www.youtube.com/watch?v=nfwNb...yer_detailpage
Aby@MIL.SPEC's Avatar
looks good.
who made the piston ring compressor?
Old Aug 31, 2011, 07:06 PM
Anarchy99's Avatar
Thanks! ARP made it
Old Aug 31, 2011, 07:38 PM
Spec-Ops1's Avatar
Looks good so far! Congrats man!
Old Aug 31, 2011, 07:40 PM
Anarchy99's Avatar
Appreciate it! Looking forward to being on the road, will have some pics of all the other money I spent haha. IE: Turbo, hot parts etc.
Old Aug 31, 2011, 09:08 PM
RSMike's Avatar
Did you measure the Mains and big end bearing clearances? or just slap it together?
Old Aug 31, 2011, 10:24 PM
R/TErnie's Avatar
Nice! I can see some thing that I need to do. Appreciate the close ups of each part.
Old Aug 31, 2011, 10:36 PM
lillev23's Avatar
86.5mm or 87mm?
Old Aug 31, 2011, 10:45 PM
surferjeff's Avatar
Originally Posted by lillev23
86.5mm or 87mm?
The ARP ring compressor states 87mm on it in the pics. 86.5mm is stock 2.4L bore. 87mm is .020 overbore on the 2.4L. Looking forward to watching your progress as this seems to be the hot engine right now and I'm already running E85.
Old Sep 1, 2011, 01:04 AM
ch53avitech's Avatar
What piston to wall clearance did you go with?
Old Sep 1, 2011, 06:28 AM
SmurfZilla's Avatar
Looks good.
Old Sep 1, 2011, 06:37 AM
Chu's Mom's Avatar
I've got the same turbo......you've got good taste my friend. Can't wait for results!
B.J.@ToxicFab's Avatar
Looks good so far man, let us know when you are ready for some ToxicFab goodies! Don't know if you remember but I actually purchased your FP Red from you early last year under a different screen name...The turbo blew after 4k miles & 1 track visit, haha, oh well!
Quick Reply: Anarchy99s First Build Thread: 2.4 Long Rod w/ Foward Facing HTA 3794 (Tons of Pics)
