Anti-Lag build Thread
Still a lot to do under the hood but here is a preview. Buschur Racing ultra-lightweight mini battery and brake booster delete kit are on their way!
Oh yeah, CBRE ceramic wheel bearings on on their way too! Curt Brown Racing FTW.
More updates coming as soon as more parts arrive.
-Jamie
-Jamie
Thanks! It actually took a lot of effort but the only wires you'll basically see in the entire engine bay will be the crank sensor wire, the two tranny sensors and the battery cables
We may even eliminate everything but the battery cables. Hopefully we can repaint the engine bay before the shootout too.
-Jamie
We may even eliminate everything but the battery cables. Hopefully we can repaint the engine bay before the shootout too.-Jamie
Thank you Sir!
Thanks! Takes alot of work but in the end it is worth it!
You mean I'm not going to have a one off, ***. lol Great piece and is light and looks great, def make every engine bay look better! Glad to see it in production!
+1000 Collins work in my opinion is the best fabricator hands down! Pictures don't do his work justice. You have to see it in person to appreciate it!
I knew i forgot something. lol
Just test fitting some parts as we are finishing up the wire tuck and for the Buschur Lightweight parts to arrive! Ill make sure to get those clamps on asap for you! lol
Thanks! That was the goal and we arent done tucking the harness yet. Jamie and I are close to being done, but still have a few stragglers to finish and the engine bay will be wire free.
Def a lot of effort to get like that, we have been losing some sleep over getting that engine bay to look that good, but it is def worth it
Hopefully Monday we will be wireless and able to test everything!
Just test fitting some parts as we are finishing up the wire tuck and for the Buschur Lightweight parts to arrive! Ill make sure to get those clamps on asap for you! lolThanks! That was the goal and we arent done tucking the harness yet. Jamie and I are close to being done, but still have a few stragglers to finish and the engine bay will be wire free.
-Jamie
Well, its alive. Just some loose ends to finish up, MORE weight reduction and then its ready for the dyno
-Jamie
http://youtu.be/9pLH9p4RFgs?hd=1
-Jamie
Well, it is finally together
we should have dyno results by this weekend and hopefully have it to the track by this weekend to start dialing in the suspension and to practice launching the new setup.
-Jamie
we should have dyno results by this weekend and hopefully have it to the track by this weekend to start dialing in the suspension and to practice launching the new setup.-Jamie
