Fairclough's "SINISTER"
Old Nov 20, 2011 | 09:44 AM
Fairclough's Avatar
06' Evo 9 MR used to be!
I will post up pictures over the next few days, our daughter just had open heart surgery!
I know there will be some haters! that's fine, disrespect me and I'll disrespect you!
Pics and info are on several different computers, so bear with me as I don't have a lot of spare time.
1880 lbs car was weighed on certified race scales (by a different shop) just too make sure! It weighed 1906 lbs, then I removed mustache bar, and several brackets that are not needed, I'm still removing weight and also designing and making lighter parts! Goal is 1780 lbs when finished!
These are older pics, I will take some this week.
Parts list:
AEM EMS
ARP head studs
Magnus intake manifold (ported)
Magnus fuel rail
Magnus mechanical fuel pump bracket
Aeromotive mechanical fuel pump
Aeromotive mechanical fuel pump regulator
-10an supply
-8an return
80mm throttle body (will be changed to 105mm)
Moran 2467.5cc injectors (235 lbs hr)
Cosworth M2 cams
BC valvesprings and retainers (these will be changed to supertech)
SPI custom exhaust manifold (bought from Trent Choi) ported and coated)
HTA 3582R w/tial v-band housing (ported and coated)
Tial 44mm wastegate
No intercooler (you don't need one at this power level on methanol)
Stage 1 Shep trans (for sale I'm going dogbox)
Stage 2 Shep t-case
6k in titanium nuts and bolts
AMS small brakes front and rear
AMS powersteering delete
AMS mustache bar delete
A/C delete
Buschur racing billet diff mounts
PST 1 piece carbon fiber drive shaft
DSS stage 5 rear axles
DSS stage 2 front axles
Motegi Trak Lites 9.8 lbs wheels
Hoosier QTP slicks
AWD spec D2's (waiting on custom titanium coils, source to be disclosed later)
Robispec 4 lbs carbon fiber rear doors
Seibon fake carbon front doors (these will be replaced with real epoxy/carbon)
Seibon fake carbon trunk skin (will be replaced with real carbon fiber/epoxy)
Seibon fake carbon hood (will be replaced with real carbon fiber/epoxy)
Custom 26 gauge harness
Sparco Evo L seat
Sparco 383 steering wheel
Sparco quick release
Ikeya Formula shifter
Custom electric shifter w/ignition and fuel cut (Pingle easy shifter)
Molded and smoothed INGS+1 front bumper (for aerodynamics)
Custom molded lexan windows
Custom aluminum dash bar
Custom -10an valve cover fitting
Custom billet rear transmission mount (will be ready in a couple of weeks)
Custom brake booster delete kit
Custom ABS delete kit
Custom line lock kit (I don't need a cnc brake lever)
Custom titanium 3" v-band exhaust (Thanks Mike from ETS) under 1 lbs
I'll update the list later, going to the hospital.
Attached Thumbnails Fairclough's "SINISTER"-ikeya-test-fit.jpg   Fairclough's "SINISTER"-lightweight-dash-bar.jpg   Fairclough's "SINISTER"-brake-booster-delete-installed.jpg   Fairclough's "SINISTER"-imag0712.jpg   Fairclough's "SINISTER"-injectors-installed-manifold.jpg
Old Nov 20, 2011 | 09:47 AM
B.J.@ToxicFab's Avatar
1780lbs?!?!? Holy crap! Looking forward to more updates on this. Hopefully your daughters surgery went well!
Old Nov 20, 2011 | 09:51 AM
Fairclough's Avatar
It did, she just got her own room!
Old Nov 20, 2011 | 10:03 AM
Boltz.'s Avatar
FCOTM Winner
That's hurts to look at. Poor girl. Best recovery wishes!!
Interested to see more about the build!
Old Nov 20, 2011 | 10:09 AM
Fairclough's Avatar
A couple more shots
Attached Thumbnails Fairclough's "SINISTER"-carbon-fiber-door-test-fit.jpg   Fairclough's "SINISTER"-imag0714.jpg   Fairclough's "SINISTER"-imag0716.jpg   Fairclough's "SINISTER"-imag0719.jpg   Fairclough's "SINISTER"-imag0670.jpg
Old Nov 20, 2011 | 10:18 AM
Fairclough's Avatar
Thanks! It's been a tough year!
I'm going dry sump, so don't mind the turbo oil return!
Attached Thumbnails Fairclough's "SINISTER"-imag0542.jpg   Fairclough's "SINISTER"-imag0545.jpg   Fairclough's "SINISTER"-imag0547.jpg   Fairclough's "SINISTER"-imag0401.jpg   Fairclough's "SINISTER"-imag0325.jpg
Old Nov 20, 2011 | 10:39 AM
Fairclough's Avatar
A couple more pics!
Attached Thumbnails Fairclough's "SINISTER"-imag0305.jpg   Fairclough's "SINISTER"-img00401-20100820-1523.jpg   Fairclough's "SINISTER"-foam-filled-evo-front-bumper.jpg   Fairclough's "SINISTER"-imag0676.jpg   Fairclough's "SINISTER"-penetrator.jpg
Old Nov 20, 2011 | 10:48 AM
Fairclough's Avatar
Like I said these are all build pics, so nothing pretty!
Carbon fiber bellmouth, we sent this one to AWD Motorsports, they used it on the Bastard!
Actually this is the one for my car, I sent a different one to Mike!
The second one is the one I sent him, this is the dyno comparisson.
Attached Thumbnails Fairclough's "SINISTER"-carbon-fiber-bellmouth.jpg   Fairclough's "SINISTER"-coated-turbo-setup.jpg   Fairclough's "SINISTER"-velocity-stack.jpg
Old Nov 20, 2011 | 11:50 AM
casper3043's Avatar
+123 for a good recovery...tough girl for sure.
Old Nov 20, 2011 | 11:54 AM
Fairclough's Avatar
Thank you! She is a fighter!
Old Nov 20, 2011 | 12:58 PM
Fairclough's Avatar
Titanium suspension bolts M14x1.25x70
FIC 1650's next to Moran 2467.5cc
Ported and coated tial housing
1 pc carbon fiber driveshaft
Attached Thumbnails Fairclough's "SINISTER"-titanium-suspension-hardware..jpg   Fairclough's "SINISTER"-injectors.jpg   Fairclough's "SINISTER"-dscn1262.jpg   Fairclough's "SINISTER"-dscn1266.jpg
Old Nov 20, 2011 | 05:18 PM
SmurfZilla's Avatar
Wow.....screw the car. Glad your daughter is ok. She looks like a new born, was she premature.
I'm a father and my youngest is a girl. I couldn't imagine. I wanted to fight the nurse that took her blood with a needle.
God Speed on recovery.
Old Nov 20, 2011 | 05:30 PM
akauf's Avatar
my nephew was born with HLHS, good luck and best wiches for your family and daughter.
your build looks very promising and totally insane! Going for the overall ET record next season?
Old Nov 20, 2011 | 05:38 PM
ssg_petty_210's Avatar
Glad your baby girl is okay. I dont know what I'd do if my little girl had to have a big surgery like that. Car looks amazing. Subscribed...
Old Nov 20, 2011 | 05:52 PM
Fairclough's Avatar
Thanks everyone! I want to be first stock block in the 8's
Then when I build the motor, I will be pissed if it doesn't go high 7's
Yes she was 10 weeks premature, 2lbs 11oz
First pic was tonight, she comes home tomorrow, second pic was 4 days old.
Attached Thumbnails Fairclough's "SINISTER"-img00128-20111120-1538.jpg   Fairclough's "SINISTER"-yawn.jpg
