700hp Compound Turbo Set-up (gt2871r & gt4094r turbos)
#151
today, started using the secondary injectors spraying VP M1 methanol
M1 methanol + water + careful programming of transition = DELTA P!
GT42 is the light blue line/green for turbine.
Red is intake manifold pressure, yellow is turbine pressure 1
Note the green line in the top graph, that is MAF lbs/min. It has been flattened in the CAL to reflect the M1 systems addition to the total fuel load. The white line at the bottom Graph however is raw MAF frequency and truly should reflect mass flow changes... Although it slowly increases with RPM it seems to plateau more or less once 32 psi is achieved and the transition occurs of turbos.
If you run it setup for absolute mode on the primary gate (PR High in green graph #4) and keep that a steady 2-1 PR, system response is faster, but Delta P overall is negative by a half Bar or so. The twist comes with the MAF freq more or less is the same in either mode, having a positive delta or negative at the cyl head.
#153
#154
#157
Well, after several years, LIPSTICK is finally coming back!
Lots of changes since I received my car last year from BTF. After a few months, noticed lots of issues
- oil, fuel, boost leaks
- 4 bar map sensor used by manifold and 3 bar sensor on another....using 4 bar map tune! Wtf! No wonder the car never ran right.
So I went to Six Sigma tuning, owned & operated by Kevin Jewer. He is actually the one who inspired me to build a compound turbo.
He drag races his 7 sec compound dsm
So he took my car to fix all the issues, and run the compounds properly.
Last week, Here’s the initial dyno run for the 116 octane tune that produced 535hp & 480tq @ 39psi.
Here’s what my compound turbos (gt2860rs & gt4294r) are doing.
It spools 29psi at 3500rpm, but I think we can even bring it down to 3000rpm
Hopefully, with more boost (5-7psi) and extra 900rpm, it will make more. So we’ll see......
Please click on this link to see dynosheet photo: http://i63.tinypic.com/2m2e7ut.jpg
[IMG]http://i63.tinypic.com/2m2e7ut.jpg[/IMG]
#158
Recently, tuner Added 5psi, LIPSTICK is now at 560hp & 520tq. Very broad powerband now.
Previously, it was at 39psi, 535hp 480tq.
We are currently experiencing spark blowout even at .22gap. This is our current limitation and not even fuel!
We’ll try using copper plugs instead of iridium and do one more day of tuning. If that doesn’t help, we’ll wrap it up.
Here’s the dyno sheet: http://i65.tinypic.com/24xe5qb.jpg
[IMG]http://i65.tinypic.com/24xe5qb.jpg[/IMG]
Clipse3GT
Jun 24, 2018 09:47 PM
FS[Northeast]: 2005 Mitsubishi Lancer Evo 144k mi(NJersey)
NJ_evoIXgsr
For Sale - Cars For Sale
Feb 11, 2017 10:38 AM
