evo gb project
Old Jul 6, 2014 | 02:35 AM
  #91
brett@evogb's Avatar
Vp import has landed results to be posted at later date
Old Jul 20, 2014 | 07:21 AM
  #92
Magnus inlet manifold with custom x8 1100cc asnu injector set up with the new k tuned 3.5 throttle body assembled by Dave Rowe @ eps
The quality of the magnus is just awesome
Old Jul 20, 2014 | 07:23 AM
  #93
Next up we have switched from the x2/3 Bosch 044 set up we were running and have found a new pump from the USA the magnafuel 4303 which we are hoping will simplify things and give us enough fuel for 1000+
Old Jul 20, 2014 | 07:27 AM
  #94
The motec custom lightweight engine harness with eight injector set up built by Dave Rowe @ eps motorsport . This is just awesome and will shed a lot of weight combined with the lightweight body loom
More updates to come
Old Aug 9, 2014 | 03:42 AM
  #95
Getting ready for the vp import map
Old Aug 22, 2014 | 01:41 AM
  #96
1027 bhp 757 torque @ 3 bar boost this is 100 percent real power straight off the engine dyno not rolling road figures
Big thanks to David Rowe @ eps motorsport
Somon @ Norris designs
Marco @ magnus motorsport
Video to follow
Old Aug 22, 2014 | 01:45 AM
  #97
Old Aug 28, 2014 | 12:47 AM
  #98
Links up
Old Aug 28, 2014 | 05:25 AM
  #99
IzzyRS's Avatar
That is badass!
Old Aug 31, 2014 | 04:53 AM
  #100
Old Nov 18, 2014 | 04:29 AM
  #101
Big updates
Big thanks to Jon Webster & the Webster Race Engineering crew for the recent work they have done on the gtir-evo drag car project :smthumbup
We took the car to have our previous roll cage removed . We choose an 8.5 spec tagged lightweight chromoly cage to be fitted . We let Jon redesign the air jack position into the rear frame also the front air jacks have been re worked and in orated into the roll cage . There is a new lightweight coloum with custom support added and new seat position .
Because of the power and high speed potential we have also added full parachute set up and now we are up to the best standards of safety with this thoroughly thought out set up the car will next be at the acid finishers for full acid strip down to get rid of any unwanted weight and debris present.
Attached Thumbnails evo gb project-20141117_221758_zpsaydmjvvd.jpg   evo gb project-20141117_221346_zpsipgkwtim.jpg   evo gb project-20141117_221315_zps3waz9hbg.jpg   evo gb project-20141117_221310_zpsq0xpdgi4.jpg   evo gb project-20141117_221007_zpssfcsfcli.jpg
evo gb project-20141117_221033_zps2tqslp5w.jpg   evo gb project-20141117_221617_zps9nraso8m.jpg   evo gb project-20141117_221038_zpsoysbjuno.jpg   evo gb project-20141117_221048_zpshbkb6vz5.jpg   evo gb project-20141117_220813_zpsbk8zdmvv.jpg
evo gb project-20141117_220942_zpsdbs2bhff.jpg   evo gb project-20141117_220846_zpsd9pez8gq.jpg   evo gb project-20141117_220748_zpsgg0hegic.jpg   evo gb project-20141117_222032_zpsja5tx6up.jpg
Old Nov 25, 2014 | 08:26 AM
  #102
Pics up
Old Nov 25, 2014 | 08:57 AM
  #103
evo_pirate's Avatar
This thing is absolutely nuts! Can't wait to see this thing ripping it up
Old Nov 25, 2014 | 09:03 AM
  #104
We can't wait either it should be sub 1000kg hopefully so over 1000 bhp per tonne
Old Nov 25, 2014 | 10:01 AM
  #105
whiteEvo08Y's Avatar
WOW Thats pretty Nuts like every other member said. Lots of work. Good luck with the project, can't wait too see it done.
