razorlab's simple build(s)
Old Sep 23, 2018 | 12:20 AM
  #1171
LetsGetThisDone's Avatar
Originally Posted by Strider327
Did you get a discount for waiting so long?
This is the automotive aftermarket. That's not how that works...lol
Old Sep 23, 2018 | 09:33 AM
  #1172
RazorLab's Avatar
Right, I'll probably end up paying more because it's taken longer, lol.
Old Sep 23, 2018 | 12:19 PM
  #1173
I was just gonna say, you probably got charged extra for having the gall to bring it in while they were busy...
Old Oct 3, 2018 | 09:50 PM
  #1174
RazorLab's Avatar
Picking up the car tomorrow. yay!
In the meantime, I was looking back into the archives and came upon this gem. Dorking around on the dyno one night. I actually think this was after I tuned the car for a time attack event and we decided to really test the tune out by having too much fun on the dyno. Can't believe this was a decade ago!
Old Oct 5, 2018 | 08:05 AM
  #1175
RazorLab's Avatar
Good news: I have the car back. Machine shop didn't charge for the work.
Bad news: Still have no idea why Cyl #3 leaked. Turbo still smokes even with the new much larger drain fitting. If I knew this head bs would have taken so long I would have taken the turbo off and sent it to Precision to get checked/rebuilt at the same time. Arghh
I'm going to bang on the car this weekend and hope that the plugs come out clean. I have a track event scheduled for next Saturday.
Old Oct 5, 2018 | 08:17 AM
  #1176
Hopefully all is well with it here on out. Sucks the turbo is still smoking.
Have you tried seeing how much oil pressure is being fed to the turbo?
Idk about the precision, but Robert Young from FP/Xona was just on the Power and Speed pod cast saying the Xona BB CHRA's can go with as little as 10psi of oil pressure feeding a .020" Restrictor at full load.
They can't leak if there's hardly any oil in them I guess
Old Oct 5, 2018 | 08:29 AM
  #1177
RazorLab's Avatar
I was kicking around the idea of putting a sensor in the feed line.
I have a .030 restrictor in there already.
Old drain fitting on the left, new one on the right:
Old Oct 5, 2018 | 08:47 AM
  #1178
.030 is all well good, but if the .030 Restrictor is getting 120psi, it might still be send too much oil to the turbo.
My car has a .020" Restrictor on the feed line for the Xona CHRA. I put a 0-30psi gauge on it. Cold start it maxes the gauge out. Hot idle the turbo it getting 6psi, hot at 6k rpm the turbo was getting 28ish. Too much oil. I purchased a turbo smart oil pressure regulator that I was going to install inline before the .020" Restrictor. It's a bypass regulator and it reduces pressure to 40psi. And then the Restrictor will further reduce pressure. It worked well on Tim's (Abacus) car,
Old Oct 5, 2018 | 09:44 AM
  #1179
RazorLab's Avatar
I was looking at that turbosmart unit but wasn’t sure how to plumb the 4an return. How are you doing that?
Old Oct 5, 2018 | 10:05 AM
  #1180
Tim ran his into the center of valve cover. Was planning to do the same. You can his in the pic under the vent line and going under the ignition cover.
Old Oct 5, 2018 | 10:30 AM
  #1181
RazorLab's Avatar
Interesting, not a bad idea.
Old Oct 6, 2018 | 10:58 AM
  #1182
Ayoustin's Avatar
How old is the turbo? PTE had hella issues with their BB stuff a few years back.
Old Oct 6, 2018 | 03:35 PM
  #1183
Jaraxle's Avatar
Between the regulator and the massively improved return line fitting, I am betting your smoking days are over. Just not willing to bet actual cash....
Old Oct 6, 2018 | 07:37 PM
  #1184
RazorLab's Avatar
Well, F me. Nothing was fixed. Put 30 miles on the car since I got it back. Pulled the plugs today and #3 piston is wet with oil and #3 plug looks as bad as before (Brand new set of plugs). What a damn waste of time and money.
So pissed right now.
Old Oct 6, 2018 | 07:46 PM
  #1185
Biggiesacks's Avatar
Fuuuuu......sorry man, must be so agrovating
