"Project Hard Park"
#766
So it begins, but did it ever really end? Seems appropriate as today we received our first snow of the season. Much easier 2nd time around. Nice to not have rusted/fused parts during disassembly.
if anyone is looking for basically new Girodisc rotors ive got mine for sale.
#774
Got most of what I need to finish my minor projects. Received the EvoX caliper bolts a while back. Waiting on 2 more bushings and 1 bearing from ESM to complete the busing install. I fubared 1 bearing during install/removal so got a new one coming. These are nice because once the housing is pressed in the arm, you can always get new bearings as they do wear out. Had to drill/clean up the dog ears for the upper rear suspension arm as the OE bolt would not fit through the hole. But it was a pretty quick fix. Have all the other bushings in and arms are ready to go besides rear lower control arms. Picked up a brand new set used on FB with the factory spherical already in them So the only bushings I needed to buy were the 2 for the shock mount. Also got my EvoX rotors today. Not sure if they had a version change or added some finishing process, but these seem to be cleaner in terms of casting flash in the rotor veins. Seem to be a bit more finished/higher quality than my previous Evo 8/9 set. Also Austin has come by a few times to make use of the press and drink beer. I gave him some of my WL bushings I removed for ESM ones. Happy New Year guys!
Spherical bearing I pressed out of the housing/sleeve.
Austin doing some work on the press for his suspension arms.
All ESM bushings installed besides the 2 I'm waiting on.
Evo X Girodisc rotors
#780
Cleaned up and rust treated my front subframe. Then coated twice in POR15. Surface finish isnt as smooth as Id have liked but I spent 0 time sanding and smoothing. All i did was wire brush the rusty spots, clean, and treat. Then paint. Shes not gonna rust anymore thats for sure.
Painted with 2 coats of POR15
After rust treatment
Just wire brushed and cleaned, before rust treatment.
