Evo IX 2.3 Liter Build FP Black Build
#466
Bring it to Vegas Jan 6th......!!!!!!!!!!!!!
#470
Update:
After almost 1000 miles of driving, I am proud to say that the car no longer burns any oil *knocks on wood*. The tuning process is moving nicely and i'm in the process of shake down and coming up with the next round of add-ons for the car.
Here is what's coming up next!
1. Due to the IACV not functioning properly ( failed the click test) I will be replacing it. When I start the car, I have to hold the throttle down slightly otherwise it starts in a "boggy" nature. My suspicion is, when the IACV is working properly it modules the idle so that the engine springs to life around 1500rpm until warm enough to settle idle, like my car did before during cold starts.
When I have my rear window defroster on and the heater, the engine stalls when I come to a stop in neutral. I'm thinking, this is because the IACV is not stepping up idle to compensate for the extra voltage load (and consequential mechanical load) the alternator now has. We shall see soon enough!
2. I am piecing together a light duty, but very capable car pc solution. Intel makes pocket sized HDMI, wifi, bluetooth windows 10 PC's called compute sticks. Some models have 3 USB ports as well as a Core M3 processor, 64gb of storage that is expandable through micro sd, and 4gb of ram. This should be more than enough to run Evoscan and ECU flash.....see where i'm going with this?
My plan is to hook one of these up semi-permanently to a single DIN video head unit and use a fold-able bluetooth keyboard with touch pad to control it. I'd connect both my Wideband gauge and Tactrixs cable to it for datalogging and live gauge display in Evoscan. I found a low profile power inverter and an HDMI to RCA converter that would help make this a reality. Everything would be hidden inside the dash and the PC would boot to login screen in under 30 seconds.
The features I would gain in the evo if I can pull this off:
1. Wifi connectivity
2. Media Center
3. Datalogging, editing, and flashing maps without carrying a laptop
4. Live display evoscan gauges through head unit screen.
5. A place to view dash cam footage
6. Ability to run G-force datalogger so that I don't have to rely on butt dyno. This will also help me adjust suspension for max grip.
7. Evoscan live map tracer.
8. Cool factor
This can be something great and I'm only worried about two stupid things. Are the tactrix USB drivers going to play nice with the Intel Compute stick and is the HDMI to RCA converter and HU combo going to butcher the resolution of the PC? Only one way to find out!
3. My front bumper is making a mean creaking noise at the driver side that I can hear on the freeway. It has done it before and I know where it's coming from, but it's annoying to fix.
4. I need to come up with a better cable solution for my gentex rear view mirror and reafix the windshield button/anchor.
5. Invest in a dash cam solution.
As always, I will be posting pictures once the projects commence.
2. Media Center
8. Cool factor
#471
Electronics are starting to roll in!
I've already setup windows 10 on the compute stick and installed evoscan, ecuflash, and updated the xml directory. I've also uploaded a selection of maps and movies for fun. Very impressed with this tiny PC so far.
Power inverter, keyboard carrying case, folded bluetooth keyboard
Intel Compute Stick, Unfolded keyboard, HDMI extension cable
Head unit with flip up monitor and HDMI to AVI 1080p converter should be arriving soon!
In the pictures everything looks big, but trust me, all these components are small.
Stay tuned for the install.
#472
Going full F&F 1 with a laptop in the car
#476
Progress has commenced. You guys have seen me wire things many times already so i'll save you the details. Everything works, but I am experiencing a noisy signal when using the power inverter(static audio sound). When I plug the Compute stick into the house power through an extension cable, there is no noise, so I know it's coming from or caused by the inverter.
Getting ready to operate and install new head unit.
Soldering in new head unit.
Making my connections for testing the new head unit with intel compute stick.
Plugging in Tactrix cable USB and UART USB to log wideband gauge.
Mounting Power inverter and RCA box
Inspecting location and determining layout. Here you can see the Power inverter and HDMI to RCA converter side by side. Fuel pump voltage gauge.
Mounting the Computer. ( I still can't believe how small it is)
Switch location for the PC so that it does not automatically start up each time I start the car if I don't need to use it.
Grounding Power Inverter
..and we're good!! All software and drivers run as they should! The car officially datalogs and flashes itself.
Now I just need to finish putting the interior back together and adjust the screen resolution so that a human being can read the text.
#477
why are you using an inverter?
You are taking ~14.5 volts DC stepping that up and converting it to 120volts AC then using a mains rated isolating power supply to convert that back to DC and stepping it down to 5 volts. You should just use a power supply to convert the ~14.5 volts DC down to a regulated 5v DC that USB runs on.
#478
You've got an excellent point there! I suppose that could work if I use a USB hub on the PC itself as it only has 1 port. 2 of them are on the power supply. I'm worried that there is some kind of protection associated with the OEM compute stick power supply. Should I just look at the ratings and obtain a DC-DC power supply with the same specs? I don't want to harm the PC.
#479
Pal215 (Dec 7, 2017)
#480
https://www.intel.com/content/dam/su...chProdSpec.pdf
I don't know if this is your model compute stick, but it says it needs 5v 4amp and it appears to be a USB-C jack. Page 24.
Quick glance through some forums and most are saying you need at least 3 amps for it to work right.
These seem to have decent reviews. add a fuse and wire it up to a USB jack and your gold.
