Evo X 2.4L s369 1.0a/r
BLOCK
GOAL is to make 950-1000whp
- Wingz performance built 2.4L
- Manley Turbo Tuff Rods w/ARP 625+ Rod bolts
- Weisco pistons
- MAP H11 Headstuds
- Darton Sleeves
- Driven Fab Catch Can -10an
- Grimspeed EBCS
- GSC S2 cams
- Brian Crower springs/retainers
- Cosworth head gasket
- AFI T4 Twin Scroll Manifold
- Borg Warner S369sx-e 1.0a/r
- Dual Turbosmart comp40 wastegates
- ETS 5in Intercooler
- Custom 4in Intake
- FIC2150cc Injectors
- Wingz Double Pumper 450's
- AMS Fuel Rail w/damper
- Fuelab Fuel Pressure Regulator
- Flex Fuel Kit
- Quartermaster 8leg Clutch
- AMS CMC
- AMS under hood shifter bushings
- AMS base shifter bushings
- AMS 5th gear gate selector
- Torque Solutions Short Shifter
Kevin Troy (May 7, 2017)
Nice setup man. I would have went larger cams to push that powerband back to the high end side but your setup looks almost like mine will end up. I will end up with a s371 with the upgrade. I opted for kelford 288s. Car made like 50 more hp from the s2 cams with a stock ported intake mani.
I am going to go with the 1.10 a/r as well.
https://www.evolutionm.net/forums/pr...l#post11673701
Man, I just posted a thread about basically this vs 2jz 240, since it will literally be about the same price, except the latter I'll have another toy.
Is this a .2 stroke and .2 overbore, or?
If you don't mind me asking, you can even pm, what was the budget around this? I figured 9-12k for shortblock, turbo, and fuel depending on sourcing of parts. Trying to get a real figure.
Zombot (Jul 27, 2017)
