My first Evo! 05 SSL
Is there a reason you are after new injectors? With a basic fuel pump walbro 255 (which is probably already in your fuel tank) the stock injectors are fine assuming youre running normal pump fuel, not e85 and are on the stock turbo. Looks like youre doing a nice job cleaning it up so dont start throwing money at problems that might not even be an issue.
I will give a list of mods currently
Know for sure mods
evo 9 turbo
evo 9 transmission (rebuilt less then 10k ago)
ecs front mount intercooler
upgraded intercooler pips, looks like it might be 2.5 possibly 3 inch
walbro 255
full 3 inch exhaust
turbo xs wastgate actuator
intake
spool up coil on plug kit
Southbend stage 2 endurance clutch
not sure about mods that the previous owner said
cams... he said it had cams..one broke?? and he replaced them..not sure oem of aftermarket
injectors. claims he put in injectors, no idea what size... But, I think we established oem
93 tune. I think it might be tuned, but not sure..and it does not have anti-lag nor any launch control enabled, can just rev to redline
While floored, it does pull good, and is really smooth. looks like 23 psi of boost and it does not fall off, I sadly do not have a wideband yet to check AFR
Thats all I have noticed as of yet.
Previous owner did other rear stuff..like put in a sub horribly that I had to remove and rewire as it was on top of the carpet and crimped the power wire whenever you shut the door. He also removed rear speakers because he liked how it sounds when all the sound comes from the front? Getting rear speakers tonight, and ordered the connectors so I do not have to cut factory wires.
You're going to need to make major changes other then the injectors from your current setup for 400whp on pump gas. And a retune will be needed, so, buying injectors now isn't a huge money saver later.
I would get your injectors cleaned. If they are dirty, it can cause fuel issues at low pulse widths and make the car run rough.
ign 5 (Apr 18, 2018)
Yeah, Alex at 5star injector solutions can turn them around quick.
Man oh Man. Devin at All Access Tuning is amazing, we have nicknamed him the Evo DR. I explained what was going on, and said I was not sure if I needed a tune, or injectors..and he said he was really busy, but he would take a look. Look is an understatement, my car is running perfect again. He started teh car for less then a second, turned it off, and was checking connectors, he checked compression, he took out the plugs and checked the pistons, he explained all the stuff I needed. He was moving stuff around and Bam, cylinder 4 I would call it, was the issue, and it had to do with spark plugs, he had a new set in stock, gaped them, put them in and running better then the day I got it. I can not thank him enough. I will for sure be using and referring him every chance I can.
I can now focus on looks while I save up some money to dump on a tune. I am buying rear speakers tonight.
Thanks for all the replies, I will post up next time something happens.
-Russ
-Russ
Sounds like you found someone to do all the basic stuff we were listing post by post LOL. It's always easier to knock it out in person than try to diagnose over the 'net haha.
Congrats!
FYI: 400whp on pump gas will require 1000cc injectors unless you don't mind pushing the duty cycle, in which case 750s would work. Then a Wally 255. There will be a turbo upgrade. FP black, maybe? I lil laggy... but if you want 400whp on pump, you gotta deal with it :P
On a side note, I was gonna say I kinda miss building on my car.. but I don't. LOL. I'm glad I just get to drive it now
Congrats!
ign 5 (Apr 19, 2018)
Devin is good. If I wasn't busy with work (real job, not my shop lol) I would have had you bring it by.
I was going to mention plugs, but one your first posts said you replaced them...?
Yea, it is very confusing. I did put in plugs, and it ran great for about 15 mins, then started running like crap again. So, I did not look at them again, I just assumed it was something else. Somehow cylinder 4 as I call it, the aprk plug tip got crushed, and had no gap at all. That is why he started looking at things, thinking the plug maybe hit the piston, but he said it looked fine. I am upset with myself for not going basic, and checking each coil to see if any cylinders did not fire. It is especially with the coil on plug kit, but just the way it ran fine at higher rpms made me feel injectors/tune. I had a problem like this in the past with one of my WRXs. Found the dead cylinder, moved coil, did not change, moved plug, did not change, heard injector clicking, but it was still the injector. oh well..live and learn, and met a great tuner.
as far as 400whp goes, not possible on the Evo9 turbo with 91?
-Russ
-Russ
-Russ
-Russ
OK, thank you for your quick replies. It will be a long while until I go that route then. I will still get a tune (any point in getting bigger injectors with the EVo9 turbo?) and work on maintenance, and cleaning it up for now. Maybe in like a year or so I will see a need to upgrade turbo.
thanks
-Russ
thanks
-Russ
thanks
-Russ
thanks
-Russ
I ran the stock turbo & 1000cc injectors & was tuned on E85 at 400 Dyno Jet WHP as an example (Evo9 w/MIVEC)
Joe
