-   Project Cars / Build Threads (https://www.evolutionm.net/forums/project-cars-build-threads-344/)
-   -   Wheatley's 6262 build (https://www.evolutionm.net/forums/project-cars-build-threads/536249-wheatleys-6262-build.html)
Wheatley Jan 25, 2011 06:54 PM
Wheatley's 6262 build-(now with 2.4LR starting page 25)
I figure its that time of year again where its time to post the build thread, Im a little behind on posting so its going to be two months of pics. First I want to go over what happened last season.Quick recap
*Sold fatfab 35r kit bought Fathouses 6262 kit
*destroyed old transmission and rebuilt transmission
*Floated valves so I sent the head to Headgames and had kiggly springs and a mild valve job. The head was then put on and taken off 3 more times until the issues with the machine work were resolved. Headgames covered all the cost but was down for over a 5 weeks. Dave was great at making sure I knew what was going on and worked very hard at having good communication.
Finally got a day off work to go race. Made 10 passes 6 on street tires (big mistake) 4 on qtp. (amazing) but the damage was already done. Twisted a brand new output shaft and had some other damage. It was still drivable but was crunching into 3rd. I removed the trans in Sept and it has been in Ohio ever since waiting on me to make my mind up.
Current plans are to keep a 6262 on the car but switch to an oil only cooled ceramic bearing forward facing Fatfab kit. Engine is staying the same, it currently has 2 seasons on the AMS block. Trans will stay a synchro box but I will be trying everything possible to keep it alive.
The car is also getting full safety equipment to be nhra legal into the 9s even if it doesn't get there. In the mean time I am having the bay repainted and trying to clean up the bay wiring.
Started late November 2010
https://i13.photobucket.com/albums/a...c/IMG_1580.jpg
https://i13.photobucket.com/albums/a...c/IMG_1581.jpg
https://i13.photobucket.com/albums/a...c/IMG_1547.jpg
I ordered a mishimoto radiator for a civic to replace my full length custom saldana setup. This should clear up a ton of room and allow for the forward facing setup.
https://i13.photobucket.com/albums/a...c/IMG_1585.jpg
I also decided to change my gauges. Before I had the wideband on the steering column, a serial gauge and two stewart warner gauges where the radio used to be. I have decided I want to see my cluster in full again and move everything over to the radio area. I just want a more factory like appearance. The oil pressure gauge from aem is all I bought to clean this up. I will use the serial gauge for coolant, boost etc. But I still want to independently see afrs and oil pressure.
https://i13.photobucket.com/albums/a...c/IMG_1588.jpg
Dec/12/2010
Got the car back on the ground this weekend. Saturday night Aaron and my buddy Travis came over and gave me a hand tearing down the car. I worked on the interior and they had most of the bay and front end torn down within an hour or so. I still have to finish removing all the wiring and brake lines but its getting there. The interior is a little farther along than these pics. Its down to the seats and heater box. Im hoping over the next two weeks to have it completely stripped and ready for the cage and engine bay respray. I also ordered some more parts ;)
https://i13.photobucket.com/albums/a...c/IMG_1595.jpg
https://i13.photobucket.com/albums/a...c/IMG_1590.jpg
Awd motorsports spec D2 coilovers.
https://i13.photobucket.com/albums/a...c/IMG_1599.jpg
https://i13.photobucket.com/albums/a...c/IMG_1603.jpg
New rear rotors arrived. I haven't had to do anything with the brakes other than front pads since Ive owned the car. The rear pads are about shot so I decided it was a good time to go all out on the rear while still retaining the rear e brake. Most of the drag kits all delete the e-brake. With this still being a street car this is the next best alternative in my opinion
https://i13.photobucket.com/albums/a...c/IMG_1607.jpg
I ordered a new valve cover. This is for an evo 9 so Im just going to shave the mivec turbo letters and powder coat it black. As well as drill and tap it for a catch can that I ordered tonight.
https://i13.photobucket.com/albums/a...c/IMG_1608.jpg
Current pics of engine and bay harness. Its just about ready to be cut up and measured for final lenght and placement of milspec connector. I will probably order the crimps and connectors after the holidays.
https://i13.photobucket.com/albums/a...c/IMG_1610.jpg
Junk removed so far, still have about 30 wires 4 ft in length to remove from whats left of the abs
https://i13.photobucket.com/albums/a...c/IMG_1609.jpg
12/30/2010
Stm overflow can that mounts to the lower part of the core support and my catch can. Both gifts from Kiley.
https://i13.photobucket.com/albums/a...c/IMG_1624.jpg
Transmission is back in my possession.
https://i13.photobucket.com/albums/a...c/IMG_1622.jpg
Current status of the tear down. I want to get the fenders and sound deading off the car this weekend.
https://i13.photobucket.com/albums/a...c/IMG_1620.jpg
https://i13.photobucket.com/albums/a...c/IMG_1621.jpg
https://i13.photobucket.com/albums/a...c/IMG_1613.jpg
New QM to replace my old worn out QM, Thanks MAPerformance!!
https://i13.photobucket.com/albums/a...c/IMG_1648.jpg
https://i13.photobucket.com/albums/a...c/IMG_1644.jpg
1/16/2011
This weekends progress.
https://i13.photobucket.com/albums/a...c/IMG_1650.jpg
https://i13.photobucket.com/albums/a...c/IMG_1652.jpg
https://i13.photobucket.com/albums/a...c/IMG_1654.jpg
https://i13.photobucket.com/albums/a...c/IMG_1655.jpg
https://i13.photobucket.com/albums/a...c/IMG_1658.jpg
Freshly painted, semi tucked and shaved. I deleted the abs last year and for the time being plan on keeping the oem brake line on the fire wall. As you can probably see tons of brackets have been removed, holes welded shut and some PS relocation under the passenger side mount. The pump and resivor are just safety wired to the rack to keep them out of the way.
https://i13.photobucket.com/albums/a...c/IMG_1667.jpg
Damn that was long, thanks guys!
batty200 Jan 25, 2011 07:01 PM
Sweet!
Wheatley Jan 25, 2011 07:05 PM
Thanks!
Pizzamangtr Jan 25, 2011 07:07 PM
Nice! that made allot of work look like it took no time at all! lol! giro ultralite?
mrboost05 Jan 25, 2011 07:07 PM
very nice build i see its been doing the right way will you have this done for IA or the shootout ? did your car wheel hop alot with your street tires random but how big is your garage ?
skyway69 Jan 25, 2011 07:09 PM
nice clean work & great garage too...
Wheatley Jan 25, 2011 07:16 PM
LOL, It really wasnt much time at all just a few hours on the weekends. The wiring I probably already have 20hrs in but that was in the house :D
I was wanting it done for IA this year, at this time Im still 800 short for wiring work and ran into some snags in the short block. It did wheel hop very bad at the strip. It never had before but it was about 80+hp more than last year. I will never drag race it on the street tires again. My garage is 24x36 with a 12ft ceiling at the lowest. I built it a few years ago on the weekends with my father in-law
Thanks and its still a work in progress but I am trying to make it a nice workspace
Originally Posted by DormantBeast (Post 9020545)
nice work! I wish i had the knowledge to rip everything apart and put back together lol
Its only time and patience. The things that are specific I either try to label or put in a special container. Most things are very easy to put back together, its generally common sense.
AngryEvo8 Jan 25, 2011 11:02 PM
Love all the progress you made so far and your garage is awesome!
Keep this updated, look forward to seeing more!
Wheatley Jan 26, 2011 04:35 AM
Thanks, Im hoping for more updates next weekend.
FathouseFab Jan 26, 2011 11:02 AM
Win!!!!
06MREvo Jan 26, 2011 11:11 AM
Progress looks awesome so far man...2011 should definitely be an interesting season...seems like there are a lot of builds going on...
SubieEvoGuy Jan 26, 2011 11:13 AM
well done sir, cant wait to see it finished.
Wheatley Jan 26, 2011 04:07 PM
The last of the parts I ordered are in. I think I have everything for the build not except the swingouts for the cage and the turbo and wastegate.
AWD motorsports driveshaft
Three Speed scattershield
driveshaft loop
Cleaned and ported intake manifold
speed element map adapter
silicone for the half radiator
all of the aluminum, stainless, bungs, clamps etc etc for the new Forward facing kit.
I was wanting to have started on the cage and turbo kit no later then next weekend but a few things came up. I have pics but will post them once I decide which route I want to go.
http://i13.photobucket.com/albums/a2...c/IMG_1683.jpg
JmanMR Jan 26, 2011 06:22 PM
looks good
EvoDom Jan 26, 2011 06:36 PM
Looks great can't wait to see the finished product
