Stock Turbo Quest for 9's
3 Attachment(s)
One year ago I had the crazy idea of wanting to create the Fastest Stock Turbo Evo in the world and be the FIRST 9 second stock turbo evo. At the time it seemed like an almost impossible goal but as the car has progressed into its gutted drag car state and all the support along the way it has become a quest of how fast can we get the car to go. As of 7/28/12 the car is making 462whp and 460wtq corrected and 458whp and 456wtq uncorrected on our Mustang Dyno here @ Dynotech Tuning. Only a few more days and we should be headed to the track and hoping to bring home that 9 second time slip. Thank you to everyone along the way who has helped, and look forward to our future projects. Here is a link to the build thread for anyone interested in more details along the way.
Power as of 7/28/2012 on Stock Evo 9 Turbo on Mustang Dyno WHP: 462 WTQ: 460 (Note: the final numbers settled in at a consistent 467whp/445wtq!) Graph: http://sphotos-a.xx.fbcdn.net/hphoto...94220425_n.jpg Weight as of 7/28/2012 Lbs: 2250 Race Ready No Driver (Goal is 2199 before DSM Shootout) Most Recent Dyno Video http://sphotos-b.xx.fbcdn.net/hphoto...79332837_n.jpg http://sphotos-a.xx.fbcdn.net/hphoto...94490609_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...21528730_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...91788683_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...00870808_n.jpg http://sphotos-a.xx.fbcdn.net/hphoto...77492055_n.jpg http://sphotos-a.xx.fbcdn.net/hphoto...08324488_n.jpg http://sphotos-b.xx.fbcdn.net/hphoto...02930434_n.jpg https://www.evolutionm.net/forums/at...1&d=1343516174 https://www.evolutionm.net/forums/at...1&d=1343516190 https://www.evolutionm.net/forums/at...1&d=1343516686 Mod List Evo 9 Stock Turbo @35psi quickly tapering to 24 Engine: Buschur Racing 2.0 LR Aluminum Rod Short Block Buschur Racing baffled OEM oilpan Buschur Racing Ported 65mm TB Buschur Racing Lithium Ion Battery (4.2lbs) ToxicFab Forward Facing Manifold Kit ToxicFab 02 Dump ToxicFab Custom 2.5" LICP for FF Manifold ToxicFab Turndown Exhaust Pipe ToxicFab 3" UICP ToxicFab 4.5" FMIC ToxicFab Coolant Overflow Can ToxicFab Mini Battery Tray ToxicFab Cam Sensor Heat Shield STM Ported and Coated IM STM Oil Cooler Delete Kit STM Small Radiator STM Oil Catch Can/Crankcase Breather STM Press-fit AN valve cover breather adapters STM dipstick with AN breather STM balance shaft inspection hole AN breather adapter Justin's Powder Coating Wrinkle Black Valve Cover and UICP Tial Q BOV Hallman Pro MBC GSC S3 Hydraulic Camshafts Supertech Dual Valve Spring and Retainers ARP L19 Head Studs AEM Adjustable Cam Gear (Exhaust Cam Gear) S.S. Valve Cover Bolts A/C Delete AMS Power Steering Delete Electrical: The wire tuck of all wire tucks! Fuel: 2 Bosch Inline 044 Fuel Pumps 3 Gallon Stainless Steel Fuel Cell AMS Fuel Rail FIC 2150cc injectors FueLab Mini Fuel Pressure Regulator Drivetrain: Curt Brown Racing Ceramic Wheel Bearings Shep Trans Evo 8 3 & 4 gears Shep Built Non ACD Tcase With RS LSD Exedy Twin HD AWD Motorsports Aluminum 2 Piece Driveshaft Torque Solution Driveshaft Bushings Torque Solution Base Shifter Bushings Avid Motor Mounts Buschur Racing Underhood Shifter Bushings Buschur Racing Side Diff Support Buschur Racing Mustache Bar Buschur Racing Center Member STM Clutch Fork Stop SS Clutch Lines Suspension: D2 Coilovers (AWD Motorsports Drag Spec) Interior: Kirkey Economy Drag Racing Seat Sparco Racing Harness Sparco Harness Bar Sparco Steering Wheel Tires/Brakes: M&T 26x8.5x15 Slicks 20mm spacers 15" Rota Slipstream Black STM Front Drag Brake Kit (Scalloped Rotors) STM Staging Brake Kit Baer EradiSpeed-Plus Rear Rotors SS Brake lines Front and Rear No ABS (RS) Aero: Buschur Racing Front & Rear Undertray OEM Mitsubishi Vortex Generator AngryAero Side Mirror block-off plates and Bumper Shutters Tuning: Stock ECU on Speed Density Zeitronix 5bar MAP Sensor Sparktech CDI PRO C.O.P. Kit GM IAT Sensor E98 Fuel [B]Sponsors On Board DynoTech Tuning http://i1109.photobucket.com/albums/...1/Dynotech.jpgAngryAero http://i1109.photobucket.com/albums/...1/update16.jpg STM http://i1109.photobucket.com/albums/...vo921/stm2.jpg ToxicFab http://i1109.photobucket.com/albums/...1/ToxicFab.jpg -Tyler @ DynoTech |
Goodluck!!!
Really can't wait for results! Glad I could be a part of this build. Looks great dynotech, now get it to the track!
Collin |
Awesome job!! Keep up the great work! It is just absurd, the creativity you have to put forth this build and push that car to where it is at!
Subscribed for some stock turbo madness
Very Nice job thus far. Awaiting track outing where all this power will be put to use.
Thanks for choosing our Ignition for this project. |
Originally Posted by lostsoulsevo
(Post 10307566)
Goodluck!!!
Originally Posted by Collin@ToxicFab
(Post 10307567)
You and me both. Going to be a great week, especially if we make it to the track like we plan. :D Were just as glad to have you on board bud! -Tyler Collin
Originally Posted by evo unknown
(Post 10307580)
Originally Posted by LGshow19
(Post 10307616)
Originally Posted by SparkTech
(Post 10307631)
Thanks for choosing our Ignition for this project. -Tyler |
Just so everyone knows this the same car/build from the anti-lag build thread! We just updated it and made it easier as the other thread was getting very long!:lol::lol:
-Tyler |
Whats the car weigh?
EDIT: Nevermind, I see it now. |
That is one bad a** evo tyler good luck at the track!
now thats a light *****
Looking good! {thumbup}
-Em |
Incredible. This just motivated me to switch to some S3's.
But oh my........I don't even want to know how much I'm going to taper on a 2.4L :lol:. |
Sweeeet, good luck!!
Holy crap, hell of a build on stock turbo. I didnt think it was possible for those #'s on stock turbo.
| All times are GMT -7. The time now is 01:46 AM. |
