Jhurley's Widebody Time Attack Build- Strictly progress
hey guys, this is a new thread for all my progress, the old thread got jacked up so I need to make a new one.
The car started out life as a stock (ish) evolution VIII with bolt ons, turbo upgrade, and E85... So i had a good platform to jump into track with. In Dec 2014 I handed the car over to Trackspec Autosports to help me complete the build. I had done a few track events with the car on the setup it was on (400whp, KW V3, stock bushings, etc) List of modifications Updated Aug 17, 2015. I will make a post under this to update my progress since Day 1 of ownership. Thanks to my Sponsors!: Trackspec Autosports, Toyo Tires, Devious Motorsports, Pristine Parts! Head: • Fully Rebuilt head- ported, polished, decked • GSC S2 274/274 Camshafts • GSC High Rev Beehive Single Valve Springs • GSC Titanium Retainers • GSC Valve Seals • Supertech STD Size Black Nitride Intake Valves • Supertech STD Size Inconel Exhaust Valves • ITM Lifters • ARP L19 Head Studs • HKS Cam Gears Turbo: • Forced Performance Green Journal Bearing Turbocharger Bolt Ons: • Stealth Short Ram Intake (Stock Airbox Hacked) • ETS 3.5’’ Front Mount Intercooler • Nisei Small Battery Kit • MAPerformance Ported Intake Manifold • MAPerformance Ported Exhaust Manifold • Evolution IX MR JDM Bypass Valve • Milspec 65mm Throttle Body • Custom Coil On Plug Kit (Denso Coil Packs) • Radium Engineering Dual Oil Catch Cans • Odyssey Mini Battery • ETS Lower Intercooler Pipe • ETS Short Route Upper Intercooler Pipe Fuel: • RC-1000cc Injectors • Waboro 255LPH Fuel Pump Exhaust: • Tanabe 2.75’’ ACD Downpipe • RRE “Stealth Cat” (test pipe with cat shield) • Invidia 02 Housing • Vishnu V-Band Catback Exhaust Cooling: • 25 Row Custom Oil Cooler Kit • Koyo Radiator • SPAL Radiator Fans • Evolution IX Thermostat Oil System: • Accusump 3 Quart Oil Accumulator (Manual Valve) Drivetrain: • TRE Ultimate Ratio Built 5 Speed Transmission (swapped) o All Shifter Bushings • ACT 6 Puck Clutch (Sprung) • ACT Prolite Flywheel • ARP Flywheel Bolts • Massimo Power RACE Rear Differential (fully built) Suspension • Feal Road Race Spec Custom Coilovers • Swift Springs: 14k Front 16k Rear • Whiteline 24mm Adjustable Rear Sway Bar • Whiteline adjustable End Links • Whiteline Roll Center Kit • Whiteline Anti Lift/Caster Kit • Energy Suspension Rear Trailing arm Bushings • Whiteline Rear Inner Toe Control Arm Bushings • Whiteline Rear Lower Control Arm Shock Bushings • Whiteline Rear Upper Inner Control Arm Bushings • Whiteline Rear Front Upper Control Arm Bushings • Whiteline Rear Lower Control Arm Bushings • Whiteline Rear Lower Outer Control Arm Bushings Chassis: • Nagisa Fender Braces (front) • AMS Front Crossmember • AMS Rear Mustache Bar Eliminator with Solid diff bushings Brakes: • Stainless Steel Brake Lines • Raybestos ST-47 Front Pads • Raybestos ST-45 Rear Pads • PF-05 Rear Brake Pads • Rebuilt OEM Brembo Calipers o Stainless Steel Pistons, Girodisc Seal Kit • Girodisc Titanium Brake Heat Shields • Girodisc 2 Piece Front Rotors • Centric Blank Rear Rotors Body/Exterior: • OEM JDM Evolution IX Rear Bumper • OEM JDM Evolution VIII MR Tail Lights • Voltex Rear Over-Fenders (Widebody) • AIT +35mm Front Fenders • Evolution IX GSR Blacked out Head lights with Blue Demon Eyes • “Nose Chopped” Evolution VIII Front Bumper • Black Vortex Generator • Shorty Antenna Aero: • WASP Composites Custom Carbon Fiber Front Splitter (Chassis Mounted) • Kognition 1700mm Carbon Fiber Rear Wing • Custom WASP V2 Canards Gauges/Interior: • ATI Dual 52mm Steering Column Gauge Pod • Authentic GruppeS HVAC Triple Gauge Pod • Greddy Oil Temperature Gauge • Greddy Water Temperature Gauge • Innovate LC-1 Wideband AFR Gauge • AEM Digital Boost Gauge • AEM Digital Oil Pressure Gauge • AMS Delrin Shift Knob Safety: • TC Designs 4 Point Rollbar Welded In • Sparco Evo II US Drivers Seat o Trackspec Autosports Custom Seat Base o Sparco Seat Rails o Sparco Side Mounts • Schroth Profi II HANS 6 Point Harness • HANS Sport II • Fire Extinguisher • Sparco Front Tow Hook Wheels/Tires • ARP Extended Wheel Studs (4 corners) • 18x10.5 +15 Enkei RPF1 Matte Black • 18x10.5 +15 Enkei PF-01 EVO SBK Finish • 285/30/18 Toyo R888 (100TW) • 275/35/18 Maxxis RC-1 (100TW) Other: • Custom Alignment/Corner Balance By Trackspec Autosports Weight Reduction: Race weight- 3130lbs with full tank of gas and all fluids • Deleted Radio, all speakers, head unit, etc • Rear Speaker Tray Deleted • Deleted Sound Deadening • Deleted Headliner • Deleted Interior Lighting • Deleted Rear Seats • Stripped/Gutted trunk (spare tire, tools, jack, etc) • Lightweight battery • Deleted Washer Fluid reservoir • Deleted Carpeting • Deleted Rear Seat belts • Deleted Rear Wiper and motor • Deleted Rear Door Cards • Mustache Bar Deleted • Front AMS Light Crossmember • Deleted Rear Bumper Beam • Deleted Center Console • Deleted Handles • Test Pipe & Catback Exhaust • Driver Seat Change from OEM to Evo 2 • 2 Piece Front Rotors • Deleted Interior trim and A pillars • More that I am forgetting. Fluids Used: • AMSoil Dominator 10w30 Engine Oil • AMSoil Premium Protection 10w40 Engine Oil • OEM Diaqueen Transfer Case Oil • Redline MT-90 Transmission Fluid • Redline LSD fluid- rear diff • Torque RT-700 Racing Brake Fluid • Redline Water Wetter Car as it sits now: https://cimg7.ibsrv.net/gimg/www.evo...27b6585656.jpg https://cimg3.ibsrv.net/gimg/www.evo...27b6585656.jpg https://cimg5.ibsrv.net/gimg/www.evo...27b6585656.jpg https://cimg6.ibsrv.net/gimg/www.evo...27b6585656.jpg |
From Day 1
Bought the car two years ago, June 2014 and this is what it looked like.
https://cimg0.ibsrv.net/gimg/www.evo...27b6585656.jpg Had bolt ons, HKS Cams, E85, FP green, KW Variant 3 etc. I knew i wanted to track the car so i went to work tracking the car, and upgrading and repairing as i went, this was pre track spec autosports take over Exhaust gaskets blew out after my first event Aug-sept 2013 https://cimg5.ibsrv.net/gimg/www.evo...27b6585656.jpg Pulled the head and rebuilt part of it after lifting the head in Dec 2013 GSC S2 cams going in https://cimg9.ibsrv.net/gimg/www.evo...27b6585656.jpg Head Decked, polished, valves polished- Dec 2014 https://cimg7.ibsrv.net/gimg/www.evo...27b6585656.jpg https://cimg6.ibsrv.net/gimg/www.evo...27b6585656.jpg Rebuilding my calipers- January 2015 https://cimg1.ibsrv.net/gimg/www.evo...27b6585656.jpg 25 Row Oil Cooler Installed- Jan 2015 https://cimg3.ibsrv.net/gimg/www.evo...27b6585656.jpg Bought some track safety gear- Sparco Evo II US, Schroth Profi 2 HANS 6 point harness, HJC Helmet w/ hans mount, etc- March 2015 https://cimg5.ibsrv.net/gimg/www.evo...27b6585656.jpg |
Track EVENTS
Second Place: Laguna Seca SpeedSF Challenge RWB Class
https://www.youtube.com/watch?v=Ldbovkaa888 Sonoma Raceway 1:55 Lap https://www.youtube.com/watch?v=ycWyfQfZCaw Thunderhill West: https://www.youtube.com/watch?v=y0kwunOW4KU |
Before and after
June 2014 VS Aug 2015
BEFORE AND AFTER TRACKSPEC AUTOSPORTS https://cimg1.ibsrv.net/gimg/www.evo...27b6585656.jpg https://cimg2.ibsrv.net/gimg/www.evo...27b6585656.jpg |
Very nice! Car looks really good. The transfomation from beginning to now is amazing. Any more plans, or are you keeping her as is?
Originally Posted by bstgsr
(Post 11494233)
Only change i need to make is driver mod ;) :lol: |
Beautiful, love the transmission whine. :)
Your car has come a long way.. love the time attack look with the flares!
I can't say enough good things about Jon and his crew at trackspec, one of the very few bay area shops I can trust to work on my cars. They provide expert and honest service. You made a good choice with them. Hats off to you. Excellent build.
Love this car and its setup {thumbup} Well done sir!
Thank YOU for sharing your 'evolution' of you car from street to track! Also, for ALL the valuable information, parts, etc.! Have a great, and safe time 'evolving'!
| All times are GMT -7. The time now is 11:19 PM. |
