Mortose's unexpected build-2011 gsr w/ bbx full
4 Attachment(s)
Hello all. So, as the title explains, I have an unexpected build happening, so I figured I would make me a nice little thread.
So, basic info: 2011 Evo X GSR. (None of that flappy paddle mess, lol) Purchased about 3 years ago in the springs. Came with a mishimoto upgraded radiator, an engine bay dress up kit, and tein lowering springs. Beyond that I couldn't tell the most anything else was touched. So, being my first evo (and awd platform) I made my way to the track 4 days later! Lol Attachment 267497 From moment one I knew I was going to mod this car. I needed more fast! Previous car was a 400+ whp mazdaspeed3. So over the course of the first year I started gathering parts for a full bolt on setup. Mostly ETS stuff. Attachment 267498 After installing everything, I got a great tune from Chet Rickerman! Car ran like a dream up until one day I was cruising down the road, did a half throttle pull and BAM! felt like I hit a wall, and no boost. Car ran fine just wouldn't get past 3 mmhg. So I limp it home and get down and dirty trying to figure out what it is. Firth thought was a blown coupler. After checking damn near everything else, I reach in to find the turbo blades refuse to spin AT ALL! http://i470.photobucket.com/albums/r...ps0izvxnld.jpg Blades bit down on the hot side and the bearings were seized inside as well as some seals that were supposed to be there weren't. Lol It just so happens that I bought a bbx full 3 days prior to this happening, so I guess it was just ment to be. At this point I needed fueling for the new snail. Attachment 267499 After installing all of that, and the turbo, re-tuned and she was running great. This is also the point that I realized that the car had been heavily modded. Most likely larger turbo and full bolt ons. Kudos to the previous owner for a decent stock out job. After that I did some visual stuff..... Attachment 267500 https://cimg7.ibsrv.net/gimg/www.evo...27b6585656.jpg Then the mod bug bit again with some peer pressure. Lol. My roommate swapped to e85 and saw a major differance, so I decided to switch as well. Insert ANOTHER fantastic tune by Chet. About a month later, cruising home from denver, car starts acting odd. Won't gain revs under wot, felt like boost cut, and lean ass AFR'S. Well, the fix: aeromotive stealth 340 to replace the failing aem unit. Barring some hickups, car was back up and running. Fast forward a month and I'm commuting to and from denver all week and on my way home, I run across a douchey STi. He does a couple revs to make his bov pop off, so I decide to enlighten him to the mistake he was about to make. At this point he decides to get off the road and I look down to find I had hit a substantial knock level. So I reset the counter and drive along normally. I notice I'm getting ridiculous amounts of knock around the boost threshold and low load levels. I man up and do a wot pull. She pulls fine and only a bit of knock as the run started. Two days later I take the car out for date night and try giving it the beans only to find its knocking all over the place. So I mosey home and don't touch it for a week. The next Saturday comes and I dive in. Plugs looked fine but I got some just in case. Then, a compression test. Bum bum bummmmmm low compression in cyl 2. So my hand has been forced. And Mr. Rickerman will be helping me out. Here is everything set to go in: https://cimg3.ibsrv.net/gimg/www.evo...27b6585656.jpg Id1300s, bc rods, weisco pistons (.020 over), all new gaskets, new MAP cast mani, gsc s2 cams and aprings/retainers, ACT clutch and master cyl upgrade, acl and king bearings, ARP main and head studs. Standard stuf. Lol And while it's been down I've grabbed up a couple more things like a new STM stainless single exit exhaust and a driven fab oil catch can/coolant overflow tank. https://cimg0.ibsrv.net/gimg/www.evo...27b6585656.jpg And here is the latest pictures of the block I have: https://cimg1.ibsrv.net/gimg/www.evo...27b6585656.jpg https://cimg7.ibsrv.net/gimg/www.evo...27b6585656.jpg Hopefully she's back to me in a week or two! Big thanks to STM for the parts, and Chet Rickerman for all the help and answering my dumb questions!! |
Those cylinders looks really good, did you find an issue on the piston/rings out of cylinder 2?
(Post 11604136)
Ah, gotcha. That donor looks good enough to possibly just need a hone or .010" overbore at the most.
I think this same issue had my friend with his Evo X just recently.
The heat shield deformed in the way that it stopped the turbine wheel from spinning. Nice parts tho! Keep up the good work ;) |
(Post 11604193)
1 Attachment(s)
Progress has been made!!!!
(Insert fast and furious jokes here... lol) |
So! Some updates on the project:
Found the cause of my issues! The top ring of cyl 3 decided to go it's separate ways.... lol https://cimg5.ibsrv.net/gimg/www.evo...bc430391b.jpeg Here is the new motor fully assembled and in the bay again: https://cimg2.ibsrv.net/gimg/www.evo...6071c8318f.jpg And now she's back home!!!!! https://cimg1.ibsrv.net/gimg/www.evo...95b6f7de1e.jpg So now it's just break in miles for a little while, then an oil change, and a balls out power tune on pump gas. Set to be installed this weekend are a new STM single exit stainless exhaust, LED tail lights, (hopefully) a Driven Fab OCC/overflow tank, and some Hella horns! Dyno results will come after the tune is complete. |
That's a good read! And on that, I'm not just tooling around in the car, I'm getting boost and what not. It's just got conventional oil in it for (what I planned) about 1000 miles, though, I'll probably run it out longer after reading that.
More additions to the build going in this weekend: MAperformance in-line fuel filter kit, radium in-line fuel pulse damper, and a cam angle sensor heat shield.
Full detail, new exhaust, fuel parts, summer wheels, and went wingless!
https://cimg5.ibsrv.net/gimg/www.evo...d547f3b769.jpg https://cimg3.ibsrv.net/gimg/www.evo...a005ba7257.jpg Here is the video for the new exhaust: |
Looks great. Specs on LED tails? Love the sound.
Originally Posted by Blue_CobaltSS
(Post 11620812)
Here is a better video of the exhaust...
| All times are GMT -7. The time now is 05:22 AM. |
