-   Project Cars / Build Threads (https://www.evolutionm.net/forums/project-cars-build-threads-344/)
-   -   Resurrection advice needed, 9 guts into 8 roller. (https://www.evolutionm.net/forums/project-cars-build-threads/754368-resurrection-advice-needed-9-guts-into-8-roller.html)
osetsky May 12, 2019 09:36 AM
So long story short, I live in Canada and imported a IX in 2011. 2015 I crashed it and been waiting to get roller since.
That has happened as of yesterday.
Roller is 2004 8 with no engine, drivetrain, transmission or lights. Or cluster. Or ECU. I don't need 'em cause 9 stuff from my wreck.
Am I missing anything essential to pull/swap?
All engine, ACD, ECU and light electrics come outta both cars and I use all the stuff from 9. HID's, cluster and ACD wiring is not compatible, correct?
Do I need to worry about ETACS stuff at all?
I'm going to drop rear diff off old car today, is it a good idea to re-stack plates myself in my apartment or is that gonna be a bad idea?
Can I leave steering stuff on new car or do I need to swap from wreck?
Yes, I've tried several searches for guys who've done this but I get 10 pages of not what I need, so keep the peanut gallery zipped!
I'll post up pics later when I figure out how to do it from my phone...if I figure out how to do it from my phone...I'm old, shut up.
CosminEvo May 13, 2019 07:10 AM
Hello,
- Most of the parts are common. The only thing that you will need to put from the evo 9 to the 8 is the engine harness complet with the ECU, because evo 9 has MIVEC.
- If the evo 8 has ACD, then the system is identical.
- Steering stuff are the same.
- Regaring the rear diff. No if you don't know what are you doing. You need some proper tools to check clearances and torques.
HyperDisorder May 29, 2019 12:26 PM
Hopefully this helps more than it confuses things:
I have a JDM Evo 8 (ACD + AYC). A long time ago I attempted to run an Evo 9 ACD ECU. It seemed to work until I hit the brakes and from what I recall, I worked out that the SRS ECU in the 9 communicated differently with regards to ABS (hence the ACD throwing an error when I got the brakes). I understand that the ABS response in the 9 is more refined than in the 8.
osetsky May 30, 2019 08:32 PM
Thanks, means I'll pretty much rip all the wiring from both and use the 9 stuff to avoid any issues like that. Plus that's a gremlin chase I don't wanna deal with.
osetsky Jun 1, 2019 08:36 PM
https://photos.app.goo.gl/FVsTEzfEwknTwB1t5
Added pics of wreck and new roller for anyone wants to see a mangled Evo and be amazed the roof is fine despite rolling twice...stupid steep mountain banks and black ice...
HyperDisorder Jun 1, 2019 09:33 PM
Given what happened, you're actually very, very lucky! Looks like a fun (and hugely time consuming!) job.
Guess you'll need to straighten out the chassis? Do you do that yourself?
MinusPrevious Jun 2, 2019 05:09 AM
Hello @osetsky
This thread certainly looks like an excellent project thread. Can you load up some of the pics vs the link?
Great story & hope to see the progress moving fwd
Cheers :beer:
osetsky Jun 3, 2019 09:50 AM
2 zomb-evo's gonna bring 1 to life
https://cimg5.ibsrv.net/gimg/www.evo...5de5c00568.png
bonus, mudflaps already therehttps://cimg7.ibsrv.net/gimg/www.evo...ad7334ff36.png
not the best work space but the weather is nice
osetsky Jun 3, 2019 01:05 PM
https://cimg3.ibsrv.net/gimg/www.evo...758a82a3a1.png
new roller
https://cimg6.ibsrv.net/gimg/www.evo...6000fc09d6.png
saddest IX
osetsky Jun 3, 2019 01:07 PM
https://cimg2.ibsrv.net/gimg/www.evo...ea7cc18ca2.png
IX interior, window was cracked and rear door no quite close so it's a mess. seats already pulled and reclaimed
https://cimg7.ibsrv.net/gimg/www.evo...74e9ca0558.png
death blow from the roll
osetsky Jun 3, 2019 01:09 PM
https://cimg8.ibsrv.net/gimg/www.evo...83ab1f485a.png
doors are fine https://cimg5.ibsrv.net/gimg/www.evo...c65ee192f0.png
even better, roof is ripple free! oh yeah, MR with the alum lid
osetsky Jun 3, 2019 01:10 PM
https://cimg8.ibsrv.net/gimg/www.evo...b432065de4.png
front pass. corner got hammered toohttps://cimg3.ibsrv.net/gimg/www.evo...a9af1c3509.png
injen piping came with roller
osetsky Jun 3, 2019 01:13 PM
https://cimg9.ibsrv.net/gimg/www.evo...f0d5c6ee57.png
new interior, gonna swap most panels as this was non-acd car and has different buttons and what-not
https://cimg7.ibsrv.net/gimg/www.evo...55ae5c1772.png
lotta freaky wiring going on, gonna rip it all and swap from wreck
osetsky Jun 8, 2019 11:30 AM
Thoughts on suspension to do while it's all a mess.
Swift Spec R(4M017R)
Whiteline BMR65XZ 24mm rear sway bar
SuperPro Front Roll Centre Kit TRC0001
Anything else to go along with that?
I already have a pile o gear to go on, some stock, some power and a sweet 2din Android head unit(Atoto A6 Pro if anyone cares) so looking to kinda dial street suspension set up.
MinusPrevious Jun 8, 2019 06:46 PM
Have you done the front & rear control arm bushes yet?
Sway bar end links could be considered?
That 24mm WL RSB is a standard Go-to. I run the same!
Dont do the FSB (not needed). Cusco lower sway bar brkt is good idea to combine w/the end links!
