-   Project Cars / Build Threads (https://www.evolutionm.net/forums/project-cars-build-threads-344/)
-   -   Gunnar's Evo 8 project (https://www.evolutionm.net/forums/project-cars-build-threads/766948-gunnars-evo-8-project.html)
Gunnar_evo8 Oct 17, 2024 07:23 PM
I picked up my first Evo a few months ago. I purchased it from the 2nd owner, and the first owner had it for 20 years. It was not a garage queen, in fact it was an NYC daily driver. All 4 doors are dinged and both bumpers severely scratched. At some point in it's life, the car was broken into and the front seats were stolen. The owner opted to replace them with base model lancer seats I'm guessing so it wouldn't happen again. An interesting thing about the car is that it has remained unmodified and mostly original it's entire life. Even the exhaust looks to be original. The paint is so faded it's practically a pink Evo and it appears someone ran over a bucket of white paint splattering it on the sides too. But it's not all bad. It's running and driving and I see the potential.
https://cimg8.ibsrv.net/gimg/www.evo...a83118fce0.jpg
https://cimg9.ibsrv.net/gimg/www.evo...64dda36770.jpg
My plans with the car for now are to first do a budget restoration fixing all the little details that have been neglected.
First things first. This Evo is so ugly and I need to do a paint correction. I'm by no means an expert at this and I'm sure there's hardly any clear left. But if I can shine it up and extend the life of it, it'll be worth it. I spent a long time with the clay bar removing all the paint splatter and other contaminants. It came out good! Far from perfect, but a presentable 21 year old high milage Evo.
https://cimg8.ibsrv.net/gimg/www.evo...db1732338a.jpg
https://cimg6.ibsrv.net/gimg/www.evo...df1916ff99.jpg
There was an EVAP leak code present. I tracked it down to some rotted evap lines under the car which I bypassed with new rubber hose. Car passed state inspection!
Intercooler Sprayer: I really want to get this quirky feature working. The hinge on the interior switch was broken. I fixed it by 3d printing a replacement hinge piece and super gluing it in. The pump is also completely rotted. After searching through windshield washer pump images, I found one that looked very similar. When it came, it's a direct fit. I did have to swap the 2 power wires in the electrical connector because it was rotating the opposite direction.
If anyone needs to repair their IC pump, here's the one I used
Heat/Cooling Blend door stuck. It took me about 8 hours to replace it. I was able to mangle it in a way where I didn't need to remove the box from the car and drain the heater core or release the refrigerant. Pretty terrible job to do but it's getting cold so it's really nice to have working heat.
https://cimg3.ibsrv.net/gimg/www.evo...86afb022e3.jpg
I was disappointed to see you cannot buy new floor mats and the cost of used mats is insane. The mats had deep heel holes. I went the DIY route and covered the holes with a heel pad. After a deep clean with a carpet wet vacuum it's smelling a lot better and looks great. I also picked up two Recaro seats locally.
https://cimg5.ibsrv.net/gimg/www.evo...283da95d33.jpg
https://cimg8.ibsrv.net/gimg/www.evo...a752bbd561.jpg
Other issues: Replaced super worn radio antenna. Fan control module broken. I replaced it with an OEM Nissan part that is the same functioning part and saved $210 versus buying OEM mitsubishi. Radiator fan was sounding clunky from rotating constantly due to failed FCM. Replaced with OEM fan. Side mirror spring broke - replaced spring from a junkyard lancer mirror. Trunk Lock Broken (maybe another failed break in attempt?) - replaced.
https://cimg9.ibsrv.net/gimg/www.evo...b2a06bff53.jpg
https://cimg8.ibsrv.net/gimg/www.evo...5a98b309d5.jpg
A little bit of surface rust in the engine bay (and some more underneath), but she looks great from 100ft away!
I'm in about $2k in parts (as budget as it gets for an Evo) and I have a semi-presentable Evo with everything working. I've been enjoying cruising it around town and taking it to work on my 80 mile commute. So far so good!
I have more planned for this car next year. I want to paint all the window trims, repaint the calipers, and re-clear the wing. I would like to get the rims refinished also. If it continues being a good car, down the line we'll see about body work and new paint, and maybe even an underbody restoration.
EVO196 Oct 18, 2024 05:49 AM
Great work, take your time & slowly the Evo will get up to par.
Where in NJ you located?
Gunnar_evo8 Oct 18, 2024 06:25 AM
Thank you. I'm in Hunterdon County.
EVO196 Oct 18, 2024 08:32 AM
ok, I'm in Morris county, very few Evos out here.
Gunnar_evo8 Oct 21, 2024 05:56 AM
Looking for some advice to confirm or deny my suspicion that my transfer case is beyond worn.
There is a whining sound that is related to wheel speed, happens in every gear, clutch in or out, and gets incredibly high pitched and loud between 70-80 mph. The noise is louder on acceleration, if I ease off the gas it quiets. The noise hasn't gotten any worse since the 1200 miles I've driven it but I would like to plan to fix it hopefully without throwing money at parts that aren't problematic. I would appreciate any advice on what the issue might be, or how I can further diagnose it.
Also the previous owner had all the driveline oils and fluids changed out by a reputable shop last year.
EVO196 Oct 21, 2024 06:10 AM
Sounds like the Transfer case needs a refreshing of internals.
Check the oil level & if it has a burnt smell to it.
Any leaks.....
Gunnar_evo8 Oct 21, 2024 06:37 AM
No leaks at all from what I've seen. Previous owner also replaced oil pan, valve cover gasket, brakes, and rear shocks. The suspension on each wheel when I had it in the air was all tight.
I should do my diligence and check the oil again. I have read filling the transfer case is difficult and an oil change does not fix the whining generally.
Gunnar_evo8 Oct 24, 2024 05:25 PM
https://cimg2.ibsrv.net/gimg/www.evo...8f70d3f55c.jpg
The fluid looks new. It even smells new. No metal or glitter to be seen. There would be at most 2k miles on this oil. I filled it back up with redline heavy weight shock. I might take it to work tomorrow, I'm not really expecting any difference. Seems kind of inconclusive now.
What could it be: wheel bearing, axle, tcase, transmission output shaft bearing? The axles feel tight with no play from what I can tell from shaking them.
Gunnar_evo8 Oct 25, 2024 05:08 AM
https://drive.google.com/file/d/1DQr...w?usp=drivesdk
Here's a video of the noise coming on strongly between 70-80mph. Still, a pleasure to drive for now if you can avoid cruising at 75.
Jahtoot_Evo Oct 25, 2024 07:13 AM
Sounds like a slight whine from the tcase. Is it getting louder ?
Gunnar_evo8 Oct 25, 2024 07:58 AM
It hasnt gotten any worse since the 1200 miles I've owned the car. It's always kind of there, but between 70-80mph it comes on as a very piercing loud sound. Symptoms are pointing to potential tcase. I drained the oil last night and there was no evidence from the oil. I would like to avoid replacing the tcase only to find out that's not the issue, if at all possible.
Jahtoot_Evo Oct 25, 2024 08:27 AM
Yea I understand. If the noise gets louder overtime I’d think it’s the tcase.
do you have a magnetic drain plug? If so what did that look like?
Gunnar_evo8 Oct 25, 2024 09:10 AM
I dont think its a magnetic plug. Unfortunately for my diagnoses, the oil was changed 2k miles ago(from prior ownership). I changed it last night again to investigate, and it looked brand new with no debris coming out with it.
Gunnar_evo8 Nov 10, 2024 05:07 PM
I haven't further investigated the noise yet. It would be great if it just got worse or something comes loose. I'll keep driving it as much as I can in the mean time.
I was feeling the basic interior needed something more but also wanted to keep it OEM and in the time period. I got a good deal on the MR gauges. Im still waiting for the oil temp sensor so that hasnt been wired yet. I 3d printed the spacers needed to mount the gauges. I also replaced the hvac label stickers to freshen it up. I'm still on the hunt for good floor mats to complete the interior.
https://cimg3.ibsrv.net/gimg/www.evo...9be670fd56.jpg
https://cimg6.ibsrv.net/gimg/www.evo...e3ec34e1c9.jpg
https://cimg9.ibsrv.net/gimg/www.evo...a78be45e08.jpg
schuhie Nov 11, 2024 08:11 AM
As someone who also appreciates the stock interior look, if you ever want to add an aux in to the stock radio, I can do that for you.
You just have to play a CD with a bunch of silent tracks for it to work.
