4G92 Mivec head to suite 4G94/4G93 Engines
FS: 4G92 Mivec head to suite 4G94/4G93 Engines
Im selling my 4G92 head from my mivec build up. Why? Because i got a hold of a 4G92 RS head.
What you get:-
* 4G92 Head
* 4G92 RS cams
* Coil packs
* Intake manifold
* MAP sensor
* Temp sensor
You can get the rest of the parts locally
* Timing belt
* 70mm idler pulley
* head gasket
Ill do cheap 1000US plus postage.. i have feedbacks ask lusion/*02lancer* and bunch of people in PR.
Ill give you the head 100% cleaned like new with bnew valve stem seals.
-Luie
What you get:-
* 4G92 Head
* 4G92 RS cams
* Coil packs
* Intake manifold
* MAP sensor
* Temp sensor
* Timing belt
* 70mm idler pulley
* head gasket
-Luie
well if you have hi comp pistons thats 180HP atw right there. Its a DOHC and a better base for future mods, what else you have mivec what more do you want. I have seen setup like this reach 150-160HP atw with 4G93 block with stock 4G92 pistons
Wow, this is awesome. It bolts up to the 4g94 with no problems? I have read that the 1st gen 4g92 is basically flipped around from our 4g94, so would this be a 2nd gen? Does the mivec run into any issues with hitting the hood?
Any pictures, and a shipping quote to the states (say los angeles) would be really helpful too. Thanks!
Shipping quotes later on the day, and pictures are on my mivec build up on lancer page.
Think this will help you sell it. Feel free to delete.
https://www.evolutionm.net/forums/la...-build-up.html
