Garage clean out, camber plate, brake pads, test pipe, HFC, ignition switch, alternat
Hawk DTC30 rear pads. 3 laps on them. You can see in the pic with new ferodo pads on the left. $100
Helix test pipe $50 High flow cat, not sure what brand. $60 RacingBrake stainless pitons. one set for one front caliper $80 power steering cooler. $30 evo 9 ignition coil and wire, have two sets. $100 each set Perrin intake. $60 evo 9 oil pump. $80 Brand new Ohlins top hat camber plates. $150 SOLD Evo 9 alternator. about 40k miles. $60 SOLD ignition cylinder with key. $40 SOLD front calipers. could use a rebuild with new seals. one pack of new centric seals for one caliper. $150 SOLD new Omni 4 bar map sensor. $70 SOLD Goodridge brake lines. two new rear line and only one new front line. $40 SOLD new OEM caliper bleeder screws. have 8 total. also 4 rubber caps. $3 each bleeder, $2 each for rubber cap SOLD partial Master gasket kit for Evo 9. $80 SOLD Evo 9 cam angle sensors unit, both. $70 SOLD mivec cam gear. $100 SOLD non mivec gear. $20 evo 8 ignition coil and wire. $80 SOLD evo power steering pump. 10k miles but the pulley is a little bent from being dropped. $40 SOLD OEM gauges. $80 SOLD DWS300 fuel pump, about 10k miles. $40 SOLD APR exhaust cover. $60 SOLD Votex style canard for voltex pumper. has been trimmed to fit Evo 9 pumper. $80 SOLD center console radio HVAC plate. $20 SOLD Evo 8.5 turbo with 10.5 housing. has about 50k miles on it. housing is semi ported. $250 SOLD Located in Carlisle PA 17013. Pickup are welcome. Price does not include shipping or paypal fees. https://www.evolutionm.net/forums/at...0142025-01.jpg https://www.evolutionm.net/forums/at...1115367-01.jpg https://www.evolutionm.net/forums/at...1126296-01.jpg https://www.evolutionm.net/forums/at...1327152-01.jpg https://www.evolutionm.net/forums/at...1219036-01.jpg https://www.evolutionm.net/forums/at...4834004-01.jpg https://www.evolutionm.net/forums/at...4844873-01.jpg |
10 Attachment(s)
Pics
3 Attachment(s)
Pics
calipers complete tho? just need to be rebuilt? lines 3 new and 1 used or just 3 total? pads are for all around right? evo 8-9? lmk interested on some of the items maybe even the 4bar
Originally Posted by Eric SlowEvo8
(Post 11803602)
three new brake lines total, I had to used use one to replace my line. kept the rest as backup. pads are for both rear calipers only, 4 pads all together. |
10 Attachment(s)
Pics
9 Attachment(s)
Pics
5 Attachment(s)
10 Attachment(s)
Pics
How much for the cam gear cover? I don't see it listed in the first post.PM me.
PM sent...
Not Too Sure If You Got My PM... are the brake lines still available?
Originally Posted by pre2dat
(Post 11811125)
up
How much for spark plugs cover? |
