FS[West]: Carbonetic/ATS&Across Twin Disk Carbon Clutch with Hydraulic Release Bearing
I have for sale a Carbonetic/ATS&Across Twin Disk Clutch with Hydraulic Release Bearing.
It has about 5k miles of use. The CF disks for this clutch start out at 3.91mm. I measured the disks in this clutch and they are 3.74 and 3.87mm. I measured at other points and the wear is even. Therefore this clutch still has a bunch of life left.
The bad news is that one of the bolts got seized and I had to grind it off. I grinded some of the front cover in the process. The stud is left in the main ring. Relatively simple to remove it. One of the CF disks has damage. A piece broke off the inner teeth. The great thing about CF is that even with this damage this does not weaken the ring substantially. CF is not affected by crack propagation.
Replacement Parts can be purchased through ATS&ACROSS. http://www.ppi-ats.com/carbon_clutch...on_clutch.html
If you have any other questions or need more measurements that aren't included in the pictures then I will be happy to provide those. Most of the hardware is included as shown.
Price = $500 obo + 50 for shipping
