FS[West]: Weldon C2035-A Fuel Pump - HIGH HP CARS ONLY
I'm selling a Weldon C2035-A Fuel pump that just was throughly gone through by Weldon to insure it's like factory new. Just got it back from Weldon. I'm using a smaller Weldon in my car, this pump is one of their highest output pumps and only for cars that are putting out 700HP or more. It's a beast -- Weldo is the best there is until you go to a full drive mechanical pump. Don't use three puny pumps to get your fuel flow -- if one of them goes, you go lean and lose your motor in a heartbeat...
Weldon's specs are as follows:
- 12 AN inlet and 10 AN outlet- Supports 2000 hp @ 14 VDC EFI (1000 hp on Methanol) 2400 hp @ 16.5 VDC EFI (1200 hp on Methanol)- 200-250 GPH / 0-80 PSI
Maximum Horsepower: 2000 hp @ 14 VDC EFI (1000 hp on Methanol) 2400 hp @ 16.5 VDC EFI (1200 hp on Methanol) GPH / PSI Range: 200-250 GPH / 0-80 PSI Features:
All billet body pumps are 100% serviceable/repairable
Self Priming Pump may be mounted above fuel cell Vertical or horizontal mount
Breakaway coupling prevents pump/motor damage in the event of fuel contamination
All internal components are 100% metallic No plastics or composite materials. Our internal pumping elements are made of high speed tool steel and bronze. This results in the longest lasting, highest quality, most durable pumps available.
Body machined from billet aluminum
For carbureted and injected engines
Provides Consistent Performance with no fall-off in flow
Precise fuel delivery
Blades self-compensating for wear
6 lbs
Current Fuels: Weldon Pumps offer the widest range of fuel compatibility. Gasoline - Methanol - Nitromethane - Diesel - Ethanol - All racing fuels
Comments: Requires appropriate bypass regulator.
T1 Race Development is a dealer for Weldon pumps. Their current price is $844. Other places sell them higher.
I'll sell this one for $575 shipped, with tracking number and full value insurance. It's literally like new internally, since Weldon just inspected it and replaced all parts with any wear with brand new factory parts.
See my feedback for happy buyers of quality high end parts. Thanks for reading.
6 lbs
Scottr126
Dec 16, 2007 10:58 AM
Scottr126
Aug 31, 2007 03:46 PM
