Full Blown EVO 8/9 Dual Pump Housing with Walbro Pumps
2 Attachment(s)
This is the original Full Blown housing that you can no longer purchase. They changed their CNC design which does not support the pumps as well as this original housing. I just sent the housing to Full Blown for them to replace the wiring and use an Epoxy that is fully supported for E85 which will make this housing as close to new as possible. It has not been re-installed in the car since being serviced at Full Blown so you are getting an assembly with all new wiring so you will have no issues there. In addition the pumps and socks on the housing are not your typical used pumps you might expect. I replaced them before the car went to AMS so they have less than 500 miles on them and there is no issues with them. They are your standard GSS342 pump with new pickups that are not all dirty from E85. In addition I will include the modified siphon tube which helps return issues some people have had. I never had an issue but I modified the siphon when I installed the setup from day one. It comes equipped with 8AN feed fitting and 6AN return fitting. In addition I will include the filter to be used between the two tanks as recommended from Full Blown. I also verified the socks are installed at the same depth as the factory pumps so this did not result in any low fuel or running out of fuel problems.
To recap you will be getting: - Full Blown original EVO 8/9 hanger setup for 8AN feed and 6AN return - Walbro GGS342 pumps that are like new with new socks - Modified siphon tube to help in pressure drop some reported with this setup You will need to provide your own lines, and electrical connections. $400 shipped. Sold |
ttt
bump pics added.
PM responded. Trades will be considered. Tell me what you got! :)
Bump
PM's responded.
spoke with you. ill call u in a few hours. looking to work something out with u
Sold!
