Spark tech coil on plug pro non cdi system | 1998-2006 evo 4-9
I have for sale a like new Spark Tech Coil on Plug PRO NON CDI System that I ran for about 3k miles before I upgraded to a CDI box. I paid over $700. Save a ton of money on a barely used unit. $500 OBO. Call, txt or email: 941-914-6614 or matthewlevonchristian at gmail. Item located in Sarasota, FL. Will ship at buyers expense.
This system features four Spark Tech spec high powered coils. This system will be a modification that you will feel. Expect a smoother idle, better drivability, increased torque, increased HP and a cleaner appearance compared to the factory coils. THIS ITEM IS APPLICABLE TO EVOs 4-9. Not applicable on JDM EVO MR models. Features Standard wrinkle black PRO NonCDI mounting plate. 100% plug and play (genuine oem connectors) 100% compatible with stock ecu & standalone ecu's Tested to 954whp @ 0.020" plug gap Military spec heat sleeve protector on wiring, rated to 428degF Tefzel military spec wire, rated to 393degF All components are brand new. Out performs the DLI Works well with stock turbo, larger turbos & fully built evos Improve idle quality Accelerates smoother through RPM range Expect longer spark plug life due to a more efficient spark Increased fuel economy (2-3mpg typically reported) Due to increased spark energy you can run more boost without spark blow out Improved throttle response Decreased in cruise part throttle surge. Smoother dyno curve. https://cimg5.ibsrv.net/gimg/www.evo...6a5a04dc55.jpg https://cimg4.ibsrv.net/gimg/www.evo...70db8a554f.jpg https://cimg6.ibsrv.net/gimg/www.evo...892fa28dd4.jpg |
I thought the 8 and 9 used different ones?
Originally Posted by GaBe511
(Post 11819114)
Bump |
Bump |
Bump |
Bump |
Bump |
Bump |
Bump |
Bump |
Price lowered $100! Someone needs to get it!
$400.00 shipped! |
Bump $300 shipped!
bump
