Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
View Poll Results: Clear
Clear
0%
Clear
0%
Voters: 0. You may not vote on this poll
All Wheel and Tire Fitment Questions and Confirmations Go Here
Old Jan 27, 2016 | 10:41 AM
  #916
SoloSpeed101's Avatar
NT03+M fitment questions
Hello guys,
Got some questions about Enkei NT03+M. I did research but did not find clear answers so I would like some clarifications.
I do not want to do any fender work whatsoever, and after doing some research, I'm looking at the NT03+M 18x9.5 wheels +27. I am aware that I will need 5 or 10mm spacers. I did read somewhere that using a 10mm spacer, created a slight shaking of the wheel and the owner dropped the spacer size down to 5mm with about 2-3mm of caliper clearance.
It looks like the go-to tire size is 265/35-18. Could I put meatier tires without rubbing and without fender modifications? Tires will most likely be Michelin Pilot Super Sports
Thanks in advance!
Old Jan 27, 2016 | 02:19 PM
  #917
TxFAkuma's Avatar
Hey guys, My Stock Advans are basically done now. The car is in storage for the winter at the moment but now i am looking to order some new tires. I can get the results on tirerack.com for the STOCK tire but i am clueless on what tires to get for the XXR 527 18x9.75 20mm offset. I'm such a newbie when it comes to tires it is unbelievable.
Can someone please point me in the direction of some tires that would fit these rims? It would just be for driving around and no track use at all. Doesn't matter if it is summer tires or all season. I'm looking for the cheapest bang for the buck.. not really.. but not expensive. I'm lowered on the Ebiach Kit and hoping not rub. Thank you!
Old Feb 3, 2016 | 12:37 PM
  #918
NEpsiOver21's Avatar
Many with 18x9.5 rims run either 255/35 or 265/35, so those are your options.. You use a popular rim, so do some searches and see what others are using, as with 265 you may or may not rub.
Cheers.
Old Feb 9, 2016 | 03:21 PM
  #919
11RalliArt_em's Avatar
Victory Function fenders
So imm thinking of getting the wide fenders for the Evo X...has anyone gone bigger than 10.5" wide and 18" or 19" with an offset?
Old Feb 18, 2016 | 11:50 AM
  #920
xamznaznx's Avatar
Currently dropped on Eibach pro kit springs.
18x9.5 +12 with rear fenders rolled all the way, with OEM tire size 245/40. Camber is set at -1.6 or so all around.
Just want to confirm if 265/35 tires will fit with no issues before I order new tires. Thanks guys!
Old Feb 19, 2016 | 06:22 AM
  #921
migs647's Avatar
I ran 265/35 R1Rs on 18x9.5 +15 with rear rolled fenders. Can't imagine 3mm making a huge difference.
Old Mar 4, 2016 | 10:16 AM
  #922
PaulyX's Avatar
Will this fitment work?
Getting 18x9.5+12 Varrstoen ES1's with 255/35/18 tire. Will this setup work? And will there be rubbing issues ?
Old Apr 11, 2016 | 02:50 PM
  #923
so I just installed Air Lift Performance air bags on the X. Ive been trying to find info on what people are running for width. Anyone out there have info on people using bags and wheel sizes?
Old Apr 21, 2016 | 01:32 PM
  #924
ecko1211's Avatar
Does anyone know if I can run the XXR 536 18X10 +25mm offset? I'm lowered on Eibachs and want to run a 275/35/18 Conti DW tire. I figure I'll need to roll the rears but wasn't sure if I will clear the calipers? Thanks.
Old Apr 21, 2016 | 04:48 PM
  #925
Baxtersevo's Avatar
Will a Volk TE37 18x9 +45 fit on and Evo 8 without rolling/pulling fenders?
Old Jun 9, 2016 | 10:46 AM
  #926
1012Xmr's Avatar
wondering if these will fit 18x9.5 ET 22 on an X with gtworx springs and no roll have a friend getting rid of them thinking bout buying
Attached Thumbnails All Wheel and Tire Fitment Questions and Confirmations Go Here-img_3004.jpg   All Wheel and Tire Fitment Questions and Confirmations Go Here-img_3006.jpg
Old Jun 9, 2016 | 07:55 PM
  #927
EVL4B11MR's Avatar
I have 18x9.5 20mm offset and i have to roll my fenders and im on Ohlins R/T
20mm and 22mm is .079 difference just depends on how low you are going to go.
I rub
18x9.5 20mm with Ohlins R/T and 265/35/18 RE71R's
Old Jun 11, 2016 | 01:22 AM
  #928
1012Xmr's Avatar
cool thanks
Old Jun 16, 2016 | 11:19 PM
  #929
tripsteady's Avatar
Hi Guys
I'm Looking at getting the Work S1rs for my Evo X. When lowered to the point in this photo, will I need anything to do anything else beside fender rolling to prevent them from scrubbing? (spacers etc.) What tire size would go best with this to prevent scrubbing?
F18x9.5J +8mm (R disc) / R:18x9.5J +1mm (O disc)
Old Jun 23, 2016 | 08:31 PM
  #930
moore0226's Avatar
Can I get away with 18x10.5 +22 Gramlights 57xtreme w 265/35/18 w/o rolling the rear fenders? I understand once I lower the ride hight I will need to.
