FS[South]: Evo 8 9 engine and miscellaneous parts
Old May 3, 2016 | 07:36 AM
boostx's Avatar
3" O2 housing and donut gasket $57
2 bbs center caps $35
Evo 8 9 rear brake caliper $95 ( just one that's all I have )
Evo 8 9 Transfer case half shaft $70
Steering wheel cover carbon fiber gauge pod $50. Some cracking in the clearcoat on the side
Cosworth Camshafts - M2 / 272 - Part # PR8102 and PR8103 - for the Mitsubishi Evolution 9.
These cams are an excellent upgrade for more mid to top end power on upgraded and high horsepower Evo's.
$395
Evo 8 powder coated COP plate $41 shipped
AEM 35lbs digital boost gauge sold
AEM wideband gauge $135
Oil pan sold
Starter plate $19
Injector resistor and fuel pump bracket $49
Intake manifold bracket $15
oem ignition Coils $54
Rear engine mount bracket $23
Crankshaft sensor plate $16
Ac compressor bracket $22
Gas tank fuel sending unit $49
Dimmer switch and bracket $22
Vacuum hard lines and sensor $25
Window weld modify Left Side Engine Mount $33
Power / Starter wire harness with fuse $35
Oil filter housing $78
Stock Harmonic balancer $52
Cam sensor and bracket $43
Timing belt pulley and bracket $22
Water pump $37
Serpentine belt tensioner w/ Idler Pulley $75
Fender side light $17
Rear main seal cover $18
2 Cam sensor $19
New Poly Trans mount insert $43
Strut bar $40
If not listed make offer
Old May 3, 2016 | 12:21 PM
import_junkie's Avatar
dibs on the wideband... PM sent
Old May 3, 2016 | 02:19 PM
Howulikemyevo's Avatar
Interested in the Evo 8 cop plate.
Pm me some picture
Old May 4, 2016 | 03:59 AM
boostx's Avatar
cop plate
Pm me some picture
Old May 9, 2016 | 05:06 AM
boostx's Avatar
still have lots of parts left
Old May 10, 2016 | 12:20 AM
Migsubishi's Avatar
Might need that starter harness, not sure yet. Will know in a few days!
Old May 17, 2016 | 03:12 AM
boostx's Avatar
bump
Old May 17, 2016 | 11:42 AM
benIX's Avatar
What brand o2 housing?
Old May 20, 2016 | 10:42 AM
boostx's Avatar
I think is a Megan O2 Housing
Old May 20, 2016 | 06:14 PM
loofee's Avatar
Interested in the 02 housing. PM me please.
Old Jun 20, 2016 | 10:41 AM
boostx's Avatar
Still have lots of parts.
Old Jun 20, 2016 | 12:52 PM
Just in case I missed it, do you have a harness for a five speed transmission?
Old Jun 25, 2016 | 04:29 AM
gqcode's Avatar
Veteran: Air Force
Is the cop plate still available if yes what color for. Evo 8
Old Jun 27, 2016 | 04:25 AM
boostx's Avatar
i have black or sliver ones
Old Jul 3, 2016 | 11:53 AM
rong.'s Avatar
starter harness
I want the starter harness.
Pm me
Thanks
Ron G.
