Hello from GB
Old Jul 2, 2016 | 01:42 AM
kev_evo1's Avatar
Hello from GB
Hi People
Heard few good tings about the forum so thought I would join up. I have been floating around Mlr and evo123 sites for awhile but they seem to be losing there ways as everyone is turning towards fb etc
Anyway I have a Evo 1 which I have had in use since 2010
Shall post some pics very soon
Been using the car as a daily and many blast down the dragstrip aka santa pod and still going strong
Old Jul 2, 2016 | 04:25 AM
Speedlimit's Avatar
Admin Emeritus
Hello!
Thank you for checking in and welcome! It is great to have you part of our community and thank you for picture!
Bob..
Old Jul 4, 2016 | 04:17 PM
Jonno99's Avatar
hey mate, tell me a bit about your Evo 1, dont really get to see to many of them around these days
Old Jul 5, 2016 | 01:13 PM
kev_evo1's Avatar
well when I got my hands on it she was only running light mods ie Air filter, 3inch turbo back exhaust a uprated clutch and lighten flywheel and that was it she run 277bhp on 10psi.
I got the car for a steal as the head gasket was blown
I replaced that and then the tuning bug started I fitted a ostrich piggy back so I could map the ecu then wound the boost up o 20 psi and ran a 12.1@111mph
But then the engine suffered crank walk so I rebuild the bottom end, Got my hands on another crank which I had hardened to help stop it from walking again, I used evo 8 mr320 piston and rods, arp con rod bolts, head stud conversion, mls gasket, balance shaft delete kit and to top it of a td05 20g
Then I decided to change the ecu for one out of a evo 6 so I could run a 3 port controller. Mapping finished @ 385bhp 370ft lbs running 1.6bar
That was back in 2012 and the engine was still going strong to this day.
Last month I took things further and took the head off fitted new guides bc springs and retainers and a brand new set of Kelford 272's
Used some nice piper cam pulleys so I could have a play with the cams found a nice setting with +2 ex +1 in
Also fitted a custom td05 with a 6sl2 20g 11 blade wheel
I tweaked the map myself, removed some timing and added fuel to get 0 knock and fuelling in the 11.5 range then went for a power run on the local rolling road and she pulled 430bhp @1.6bar
Old Jul 5, 2016 | 05:25 PM
Jonno99's Avatar
wow that's great for such an old car, must be the fastest Evo 1 in England, have you done any drive train upgrades?
Old Jul 9, 2016 | 03:05 PM
kev_evo1's Avatar
Mine is very light weight compared to a few other early evo's in the uk, There is one running 800+ and a fair few around 500-600 marks
Old Jul 15, 2016 | 09:47 AM
DRiddick82's Avatar
WOW... another stunning car.... welcome to the forums... talk about "old school"
DecepticonsMR
Northwest Region
38
Oct 6, 2010 09:08 AM
MADMarc
Feb 24, 2010 07:33 PM
redteam22003
Aug 16, 2005 06:46 PM
