96534706 - 2150 - Idle issue
Old Jan 17, 2017 | 11:48 PM
mines5's Avatar
Hi guys ..
Just started to tune 2150s + Omni 4 bar on pump gas . They dont fire on 96534706 with out pressing the paddle . Running open loop. at idle. I tried different latencies and scalings but they wont fire on the key. Min ipw used - 1.072 , 1.104 , 1.112 .
Any one faced the same scenario ?
Old Jan 18, 2017 | 07:18 AM
mines5's Avatar
Bump -
2150 and SD people
Old Jan 18, 2017 | 07:58 AM
4b11slayer's Avatar
What is your throttle position reading on evo scan?
Old Jan 18, 2017 | 08:15 AM
mines5's Avatar
Hi 4b.
It reads 13.3 %
Old Jan 18, 2017 | 08:31 AM
4b11slayer's Avatar
Sounds right, i know if its above 16 it causes your complaint.
Old Jan 18, 2017 | 08:39 AM
mines5's Avatar
You did min ipw patch?
I did min ipw patch bro. I have tried these 3 ipw values . 1.072 , 1.104 , 1.112 on 965347
Its quite odd that 1.104 works well on 90556701 + JB latencies.
Switched to 9653 and it never idled. What are your MAP VE values in idle areas ?
Old Jan 18, 2017 | 09:04 AM
4b11slayer's Avatar
74 or so
Old Jan 18, 2017 | 09:58 AM
Fast_Freddie's Avatar
Veteran: Navy
Lower your Cranking IPW from 7 to 82 down... from 50-82 I would have it at .5ms
Old Jan 18, 2017 | 10:06 AM
mines5's Avatar
Thanks for the reply freddie.
Lower them using formula -- stock value [ old scaling / new scaling ] ...
Do i need to lower the VE values in Idle areas as well ?
Scaling and ipw have inverse relationship ?
Old Jan 18, 2017 | 02:19 PM
Veteran: Navy
I just lower them until **** works...
Old Feb 20, 2017 | 12:02 AM
mines5's Avatar
Update -
In case if some one is going through this problem [ pump gas ].
John Bradley's Latencies are spot on.
Lowering Cranking IPW helped.
Increasing MAF comp vs coolant values in lower temps.
Adjusted the BISS.
Car fires up right away on key with out pressing the throttle.
Thanks everyone for the help.
Big Bald
Apr 6, 2018 10:34 AM
outtanowhere
Dec 13, 2017 09:23 AM
EmeryatSTM
Mar 14, 2010 11:52 PM
Toxin
15
Mar 14, 2009 12:47 PM
shanezt
28
May 2, 2008 08:30 AM
