Forced Performance Finally Releases the HTA3794.. 900+whp Capable T3!!!
Old Jul 12, 2010 | 01:58 PM
  #46
ericblackevo8's Avatar
Ok, so how do you think this turbo will perform against the 6765 on a similarly setup vehicle?
Old Jul 12, 2010 | 02:00 PM
  #47
AWD Motorsports's Avatar
From what i have seen on our more mild Mivec setup it will make more power than 6765.. It made more lb for lb already.. So i would say on kill mode it will make more..
Mike
Old Jul 12, 2010 | 02:02 PM
  #48
Nice! Whats the pricing on this unit?
Old Jul 12, 2010 | 02:05 PM
  #49
Pm for pricing.. Im not able to discuss in the general sections.. Thanks!!
Mike
Old Jul 12, 2010 | 02:13 PM
  #50
whitepwr's Avatar
Most 6765 setups make between 650-750whp on average.. this looks like on a pretty mild setup it's making 850whp+ and like Mike said, on kill mode 900-950whp should be attainable.. I've yet to see a 6765 setup make close to that lol.
Old Jul 12, 2010 | 03:06 PM
  #51
twkdcd595's Avatar
You do realize they (AWD) made like what 920ish+ whp on this dyno as well with a billet 6765 precision.
I am curious to see a dyno layover of this vs the 67mm precision billet on a similar setup to properly compare them.
Interesting stuff.
Old Jul 12, 2010 | 04:04 PM
  #52
whitepwr's Avatar
Yah they made that on much higher boost and a much more aggressive setup. This turbo will outperform the 6765, the only reason theyd even do it is just to show by how much it beats the 6765. Lol this one only made 19hp less.. Throw like 2more psi at it and there you go, youve matched their highest dyno for a 6765.
Old Jul 12, 2010 | 04:06 PM
  #53
Originally Posted by twkdcd595
Mike made what 920ish+ whp on his dyno with a billet 6765 precision... fyi.
Interesting stuff.
Correct.. he was saying Avg setups he has seen.. You need to have the combination perfect to make the big power on either turbo..
Mike
Old Jul 12, 2010 | 11:49 PM
  #54
JohnBradley's Avatar
Originally Posted by Broham
nick,
aaron,
You guys should run a t3 setup instead of the black and go with this turbo. with the silly tuning of ER, you guys might break 1000wheel! just make sure to have a neckbrace handy because I imagine if this thing hits boost at 40 psi, youll get some violent pressure to the neck
I would have to be really silly, unfortunately I dont think that would happen as Mike pointed out. I am 50whp (lets say 5 lbs/min) above what the 3586 is rated (around 75, though 73 is hinted at). The 3794 is being billed as a 90 lb/min. I see 950whp about the limit, regardless of who is tuning it.
There are ways to get more, compression, fuel, even more aggressive headwork, etc. but I dont see that being practical for most budgets. I wont be tuning Nick's car when its all done and I am not sure I want to change my current setup. We'll see anything is possible.
aaron
Old Jul 13, 2010 | 12:44 AM
  #55
alex_s817's Avatar
pretty impressive for a t3 housing
Old Jul 13, 2010 | 01:45 AM
  #56
NickieBlaine's Avatar
aaron
If only you werent on the other side of the country....
Old Jul 13, 2010 | 08:37 AM
  #57
Broham's Avatar
id assume with a 2.4 spool will b e helped significantly. this still would probably be too much for a street car definately. 950wheel is silly as it is. i look forward to many dyno results threads with this turbo. i can't believe 950 wheel is this attainable, with proper setup. turbo must sound great and must feel amazing when it "hits"
Old Jul 13, 2010 | 04:19 PM
  #58
twkdcd595's Avatar
I am sure we will see more from this turbo and can draw a better comparative conclusion to the 6765. Looks promising from what information we have in this thread from AWD.
Whatever the case of the setup though, your comment was you have yet to see "a 6765 setup" (as in any by the context) make close to that (as in the 901awhp this unit just did and this thread is about). You did not specify any conditions in your post and my post was responding to that incorrect generalization that a 6765 setup has not made make close to that power. Thats how it reads and how I responded. Sorry if it sounds critical of your post.
Old Jul 14, 2010 | 02:28 PM
  #59
EvoDan2004's Avatar
Originally Posted by evodan2004
At what rpm does this Turbo hit 30 PSI vs the hta86
mike when does this turbo hit 30psi on the 2.0l?
Old Jul 14, 2010 | 08:45 PM
  #60
italianevo88's Avatar
man thats a badass turbo, cant wait to see some builds with this
