Twin Throttle Bodies
For those that have been waiting...dave told me that they are making them in january. Cant wait till this, would really liek to see somebody do it. Just thought some of you that have been wondering (liek eboy) would liek to know.
ok since we would be getting rid of the maf, we would need to get engine management to read from a map sensor correct? i read somewhere that you would need a standalone for this, why wouldnt an emanage be sufficient since they have the ability to read from a map sensor?
from what i've read, you'll still be able to retain the MAS. rpw seems to be going with the old VW style dual throttlebody setup where both butterflies are in one unit on one side of the intake plenum chamber. if they went with the same setup as the the 1.5L MAP systems, it'd be pretty hard to get both TB's piping connected to the MAS as the TBs are on opposite sides of the manifold. if the MAS can still be used(which it seems like it will be), fuel upgrades and a normal piggyback would seem to suffice. this kind of development is what has been delaying the setup from finishing cuz i remember hearing about this a loooooooong time ago too.
why an emanage won't work is because the pressure sensor is used in conjunction with the MAS. only because the ecu still needs a MAS reading to operate correctly. the pressure sensor is independent and the emanage doesn't convert pressure readings to MAS frequency. the pressure sensor is used to control fuel above what the stock sensor can read. even though the ecu will hit a sensor "ceiling" with the stock sensors, the emanage will still make adjustments based on the pressure sensor.
and porting and polishing is something you do way down the road, it would give NA guys minimal gains. i was told that PnP the head really give no appreciable gains until you are over 13psi anyways.
yes, rpw makes a quad throttle body setup, not sure if its on our cars or not, i woudl assume that they can do it but they have a set up for other cars and with quad throttle bodies and i was told that it actually produces 2 psi of boost in the intake manifold.
gregivq - i wouldn't worry about getting too much air with twin throttle bodies when there are people forcing 5+ psi of boost in there with no probs.
The quad tb's were supposed to give 40-50% increase in hp but that also required a stand alone engine management system. Hopefully only a piggy back will be needed for the twin TB.
WADAD
WADAD
if these duals come out i may decide to stay N/A... it should give me all the power i want until i can afford a better car... or hell... i think you can through Twin tb onto a turbo setup cant you lol
