IX Engine idle noise (belt?) (video)
Old Apr 7, 2007, 11:14 PM
JT-KGY's Avatar
Anyone else got this noise?
Sounds like noise came from the belts
(or at least coming from that side of the engine).
Car/engine is stock... noise started around a week ago.
Only thing I think can of is that overfill the engine oil a little bit.
Edit from llDemonll:
Additional video with the noise in better quality
Old Apr 7, 2007, 11:24 PM
Clutchdc5's Avatar
hrm...i have a sound like that but, mines sound like metal on metal, like a RING
overflowing engine in oil is REALLY bad. make sure your not past the full mark
Old Apr 7, 2007, 11:35 PM
JT-KGY's Avatar
How is it really bad? Other than the fact that manual says not to do that?
Old Apr 8, 2007, 09:06 AM
One Wicked EVO's Avatar
you create to much crank pressure theres only so much oil it can hold till it has to be pushed out of somewhere
Old Apr 8, 2007, 09:14 AM
lancersibling's Avatar
you'll get degraded performance and as stated above, too much pressure built up in the motor. eventuallly the oil will find somewhere to go.
Old Apr 8, 2007, 10:24 AM
BOOSTEZ's Avatar
That sounds like your timing belt or pulley (or crankshaft).
It's definitely something turning with the crankshaft.
-M
Old Apr 8, 2007, 11:23 AM
jopinoyz's Avatar
Smile
hey, i have the same sound too.
in the morning (engine are cold) sound like old belt, when its hot noise goes away.
So, i change the crankshaft belt, after that still have the same sound. but goes away when the engine is hot!
i dont know! more info PLEASE
Old Apr 8, 2007, 02:48 PM
JT-KGY's Avatar
Not sure about cold.. but mine is there when the engine is warm/hot.
Old Apr 8, 2007, 06:24 PM
barneyb's Avatar
The reason for not overfilling the crankcase (above the top mark on the dipstick) is to keep the crankshaft out of the oil in the pan. First, pounding the crankshaft into the oil absorbs horsepower. Second, the oil thrown around by this can lead to oil foaming and ingestion of air by the oil pump. Finally, the atmosphere in the crankcase can become mostly made up of tiny oil droplets that when impacted by the crankshaft add further drag to the crankshaft.
The sound I hear sounds like either some loose metal or a bad bearing.
Old Apr 8, 2007, 06:54 PM
TKPIXMR's Avatar
I have the same sound, my just had a few mods. it on and off even when engine hot.
Old Apr 8, 2007, 07:52 PM
evolved83's Avatar
my IX does it too... im guessing its common
Old Apr 8, 2007, 08:00 PM
Seranin's Avatar
same sound as my car, though mine seems more intermittent. I'm finding more and more to ignore minor sounds with this car...hey, it's a mitsubishi, right?
Old Apr 8, 2007, 09:00 PM
JT-KGY's Avatar
Thanks guys.. so maybe it's common... mine started to have the noise just
last week.. around 12k mark. Car drives fine though.
Old Apr 8, 2007, 09:01 PM
JT-KGY's Avatar
Thanks for the info on the overfill too... I'll make sure I wont overfill again on the
next oil change.
Old Apr 9, 2007, 10:42 PM
JT-KGY's Avatar
I listened more closely today.. really sounds from one of the pulleys or belt...
How involved is it to remove/replace those?
Thanks,
Quick Reply: IX Engine idle noise (belt?) (video)
