Most aggressive wheel spacer on OEM wheels?
What is the most aggressive wheel spacer I can run on a factory Evo X wheel lowered on coilovers, stock camber? Can I run an Ichiba vs 20mm or will that require rolling the rear fenders?
remember when you put spacers under your wheel your studs gets more stress. As wider the spacer gets the stress also rapidly gets bigger. That is why some races they do change the studs for stronger and longer ones.
Just keep it in mind.
I am def. not a fan of spacers. Get a better offset wheels instead . that is safe . Or get longer stronger studs. they would cost around $500 installed.
Anyone else have input on size without a roll?
I'm running 25mm spacers all around on KW V3's (but I dont' have it slammed). No fender work... about 1.4deg rear camber and 2.2ish front. Probably could make it work with less... I did trim and mold my front fender liners a bit... but that's it.
Given that it's the tire, not the wheel, that first hits the fender lip in the rear, and that different tires - even those with the same numbers on the sidewall - are different widths at the shoulder, where it matters, the question posed in this thread cannot be answered.
To be clear: some 245/40/18s might not rub even with a +25mm spacer; other 245/40/18s might rub with any spacer larger than a +15mm.
I only tried +15s, but if you search around, I believe you'll find posts saying that +20s don't cause rubbing with the OE tires. It's things like R-S3s and some Pilots that I worry about; those are quite "square."
The key point, which I believe came across, is to search for the tires as well as the spacers before deciding. Or just play it safe with +15s. After all, wheel bearing prefer +15s.
