Headlight Switch Wire! Need the Color of wire...
Old Jun 2, 2015, 04:52 PM
reil_neil's Avatar
Im installing a wideband and requires the WHITE wire to connect to a Headlight Wire. Anyone know of the color of the Headlight wire by any chance?
Old Jun 6, 2015, 01:30 AM
justin_l_'s Avatar
https://www.evolutionm.net/forums/ev...ll-w-pics.html
This thread says you can use the green/white wire located at the dimmer switch if you want on/off without dimmer.
Further down it somebody mentions that you can use the yellow/black wire at the dimmer switch if you want to be able to dim your gauge..
Old Aug 20, 2018, 12:42 PM
kaj
kaj's Avatar
Just came across this during a search. For future reference: DO NOT use a dimmer wire power source for an electronic gauge (wideband/e85/other electronic gauge) operation. It needs full voltage to operate correctly. Electronic gauges detect power to from the headlight switch so they know to dim.
The potentiometer of the DIMMER switch is wrong for powering electronic gauges. It is ONLY okay to use for the light bulb in a gauge (mechanical boost/oil/water/etc) so that it dims with the gauge cluster.
kpt6
Feb 26, 2013 12:58 PM
AlienEvoX
17
Oct 9, 2009 02:17 PM
Nasty Evolution
Jun 28, 2009 11:43 AM
mmartahus
10
Dec 22, 2008 03:06 PM
lacartus
Aug 24, 2005 10:21 AM
Quick Reply: Headlight Switch Wire! Need the Color of wire...
