track car suggestions / discussion
So earlier this year I bought myself an RSX-S to be my track car cause I came across a good deal. and cause of the good deal I didn't even consider anything else... well 5-6 track days and an autox later, and going on some ride alongs, I'm thinking maybe I don't want FWD for my track car.
I know this is an evo forum, and I've had an evo X before (sadly never tracked it, only autox), but try to remain impartial
my max is about 15k but I'd prefer to stay under 10k.
needs to be rwd or awd
turbo acceptable only in awd (SC ok with either)
doesn't need to be powerful, in fact I prefer not very powerful
needs to be reliable and not need a ton of work to get it track ready. I want a car to drive, not to work on.
while this won't by my daily, I don't want it to be a stripped out track only car. I will drive it on the street also.
cars I'm considering. if you have any tracking experience / knowledge about these, please chime in with whats required to make these track reliable (oil cooler, etc) other than the obvious tires and brakes. for the older cars, what needs to be refreshed. anything else worth considering
FRS/BRZ - would most likely buy this one at a salvage auction
S2000
Miata - if I find a good deal on a SC'd one. I don't really want to have to deal with SC'ing it myself, and NA they're just too slow. so this factor puts it in the unlikely list
E46 330 - but kinda scared after reading vorshlag's thread on a build they did and all of the worn BMW crap on it. this one is pretty low on my list (http://www.vorshlag.com/forums/showthread.php?t=8400)
Evo 8/9 (really 8 at my price point) - I'd have a low power track tune for it, somewhere between 250-280 whp
open to other suggestions also
cars that are out
STi
350Z - this would actually be perfect if it wasn't for a hot engine that ate oil and crappy tranny and flimsy uprights and the list goes on...
and a pic of me in action for bonus points
if anyone is curious about the RSX, most of the stuff I did to it and some review can be found here
http://forums.clubrsx.com/showthread...354&highlight=
S2000
cars that are out
STi
EvoM Community Team
I know you are not looking to replace your evo, but here are some things on track weapon discussion:
https://www.evolutionm.net/forums/mo...tside-evo.html
https://www.evolutionm.net/forums/lo...xt-merged.html
You can get a turboed mazdaspeed Miata that's like 205hp, too.
I couldn't own a Miata. But that's just me.
I see an Evo 8 in that price range being a basket case car, no thanks.
Rebuilt frs or brz would be good as long as you knew the frame was properly straightened or repaired as needed.
the way a car feels when driven hard is more important to me then all out speed or time. I really hated the RSX at autox. Track is pretty decent with how I have it set up right now... but I wanna move away from fwd.
I actually looked into a MS Miata. turns out they're not that great for tracking. somehow they don't come on boost till almost 5k rpm, they have over heating issues, they really need a stand alone to run properly and I have to pass emissions every 2 years, so thats more or less out (although if I get a PNP unit I can plug in the stock ecu when I go in for inspection). really needs about 5k worth of crap before its a decent track car
yeah, thats kinda what I'm thinking with the FRS/BRZ. I've bought salvaged cars before so thats not an issue. I wouldn't buy one that has frame damage, its usually fairly obvious from pics. anyone know anything about if it needs anything to be a reliable track car? how does the stock radiator handle the heat, does it need an oil cooler?
How about an LS swapped 3rd Gen RX7? http://www.norotors.com/
also a lot faster than what I want... an no ABS... being still somewhat of a n00b, I like to have the safety net of ABS for those oh sh*t moments
This might be a bit far out there, but is it possible for you to source a salvage title EVO 8 shell and build from there the way you want? You can source a cheap 4G64 or 4G69 block for $600, get a used EVO 8 head for about $650-900, then start building. You don't need huge power, so you might get away with buying a lot of used OEM parts.
EVO shell - aim for $3,000, salvage title or theft recovery is fine if it's just your track build
4G64/9 block - $600
head (used) - $900
valvetrain (new) - $500 (throw in some nice valves/springs/seals)
cams (new) - $500 (gsc s1, s2 etc...)
gaskets (new) - $400
pistons (new) - $450
rods (eagle, new) - $320
crank (used) - $200 (a stock 4G64 should suffice, can probably get cheaper or just buy with the block)
oil pump (new) - $230 [i'd recommend going new, it's a known bottle neck]
5spd transmission (used) - $1000
t-case (used) - $1000
rear diff - $800
clutch (new) - $500
with the shell you can probably get the axles, driveshaft, subframes, possibly stock suspension/linkage
at this point you're up to about $9900 with a built engine, new clutch...
Turbo is really up to you. FP Green or the like is a good extra few thousand. Finding a used stock frame setup would be less.
This assumes you can do a lot yourself, though. Machine shop costs might be around $500-1000 depending on what you need done and where you live.
If your budget is $15k, you still have a few thousand leftover to address any other areas of the car you want configured for a track car - suspension, brakes, roll bar etc...
All in all, you'll get a car tailored for your needs, with some performance parts bought new and it will be less than that of any complete EVO 8 you'll find.
Would be a major commitment and lots of researching deals online or locally, but I'm sure you can pull it off and still be under $15k.
4G64/9 block - $600
head (used) - $900
rear diff - $800
clutch (new) - $500
4G64/9 block - $600
head (used) - $900
rear diff - $800
clutch (new) - $500
4G64/9 block - $600
head (used) - $900
rear diff - $800
clutch (new) - $500
The 3rd gens had ABS. You can even update the ABS http://www.norotors.com/index.php?topic=2737.0 Most of the parts are bulletproof, as long as its built correctly it shouldn't require much "tinkering"
and theft recovery evo's are pretty rare, typically if they're stripped, then literally everything is stripped. it'd end up costing a lot more than 10k. although I'd be open to buying an evo with a blown engine for the right price...
