Evo X Electrical / Audio / Security Discuss electrical and audio system upgrades or alarm configurations.
10.2 Android 6.0 Q/A
Old Mar 23, 2017, 11:21 AM
NinjaX's Avatar
Starting a new section for the 10.2 Android 6 version with PX5 CPU, since the old treath is for 5.1.1. If you have that unit ask questions on the other tread. Link to the 5.1.1 https://www.evolutionm.net/forums/ev...av-stereo.html
Old Mar 23, 2017, 02:29 PM
Robevo RS's Avatar
cool. any good suggestions about the set ups , customizing etc?
That would be help full I guess.
By the way, its easy to set up with the USB wireless data stick? I am thinking to get one for just a unit. I think its less then $10 a month Sprint.
Old Mar 23, 2017, 02:31 PM
Robevo RS's Avatar
What I meant, go into factory settings Password 126 , and change button colors. I liked the RGB red option.
Also I picked of course the Mitsubishi logo option on start up . etc.
Old Mar 23, 2017, 02:49 PM
NinjaX's Avatar
I actually have the Final Edition logo on my start up, i will post all the passwords i know so far in a few.
if anyone have a png of the MR Red logo will be great too.
Old Mar 23, 2017, 03:06 PM
NinjaX's Avatar
Firmware
I got this from xda forum, just reposting here for reference on the evom forum.
Installation instruction:
Unzip update.img to the root of the GPS SD Card.
Make sure you Don't include the dmcu.img if your MCU does not match the MCU of the firmware.
Latest Firmware:
20170304 - GS MCU
Link: https://1drv.ms/u/s!AjrY0uqbW_kBgw2az8UBZblxizSy (thanks to @drukhadze for the link) from xda
or
Link: https://1drv.ms/u/s!AjrY0uqbW_kBgxd715vm7ZcxK6yR - MCU dated 20170314 (thanks to @Ga73 for the link) from xda
or
https://www.sendspace.com/pro/dl/fgu9yr its just easyconnect apk
provided by HotAudio
https://www.sendspace.com/pro/dl/rh06te
provided by hotaudio.
Dasaita/hotaudio MCU and FW: Dasaita mcu updates rockchip px5 octa
Old Mar 23, 2017, 03:07 PM
Robevo RS's Avatar
please NinjaX check if i missed any steps here. Since you posted the links i have nothing else to do here lol
But maybe this helps a bit. if not i will delete it .
I unzipped the files, and individually pasted on the memory card.
Then i did go to settings in the unit settings menu.
MCU file click update. start update ,The unit restarts
When its restarted it will asking for a new install file which it will found. click yes, and the reinstall will start , replacing the whole OS.
Is that simple. But will delete everything is personal file though.
After that i had to delete my install files from the memory card because every start up, the unit asked for the new install.
Old Mar 23, 2017, 03:12 PM
NinjaX's Avatar
Password @ your own risk
126 - opens facotry settings app (Device customer name beginns with RM - parameter ro.product.customer).
3333 - opens facotry settings app, only logo change screen
m123456 - opens facotry settings app with bit other parameters...
adbon - enables ADB
adboff - disables ADB
keject - sets ctr_key to eject
kpower - sets ctr_key to power
hcttouch - display some touch info. probably touch panel area size in pixels
hctreboot - initiates device reboot
hctbtup - writes on screen "BT updata!" , Sends Android Intent
hctbtte + 3 digits - probably starts some tests with bluetooth adapter. but no information what this 3 digits meaning
logcls - clears logcat
logcat - executes logcat as follows [b]logcat -f <filename> -v time
filename = <external storage>/<current date+time>_android.txt
kmsg - excutes dmsg command and writes output to <filename>
filename = <external storage>/<current date+time>_kernel.txt
radio - executes logcat as follows [b]logcat -b radio -f <filename>
filename = <external storage>/<current date+time>_radio.txt
logcan - starts CAN bus logging app
1199 - enables/disables HZC_MENU . I don't know what it is
v5555 - Enables/disables Video while driving. Enable also removes "Watching video" under Car settings
hcttest + up to 3 digits - not tested yet.
Robevo RS (Mar 23, 2017)
Old Mar 23, 2017, 03:14 PM
NinjaX's Avatar
Final Edition Logos
here are some of the logos I created for the start up.
Old Mar 23, 2017, 03:16 PM
NinjaX's Avatar
put the files on the SD card instead of memory, go to system update and perform the updated. you can also do only dmcu first and then update.img but you will nead to leave only the file you want to udate at the time. I will try to do a video recording in a few of this process and will post it here.
I unzipped the files, and individually pasted on the memory car.
Old Mar 23, 2017, 03:17 PM
Robevo RS's Avatar
Can you do a ralliart logo maybe ?
Old Mar 23, 2017, 03:18 PM
Robevo RS's Avatar
shoot I forget to put the D there lol
I meant card not car.. thanks for fixing it.
Old Mar 23, 2017, 03:21 PM
NinjaX's Avatar
S-awc
Not a fan but I have a friend that likes this one.
Old Mar 23, 2017, 03:24 PM
NinjaX's Avatar
RallyArt
NinjaX's Avatar
to change the car logo go factory settings, use 126 then car logos, place the logo on the root of the sd card first then browse it and click animate.
Old Mar 23, 2017, 03:30 PM
Robevo RS's Avatar
Quick Reply: 10.2 Android 6.0 Q/A
