flashing 2003 Airterk turbo R
hi, I'm a first time flasher, I have two Airtreks 2002 and 2003 Ive pulled both roms using tactrix 2.0 and ecu flash and active matrix. one is very detailed the other missing or grayed fields, want 03 to run like the 02, can I just do strait copy of my o2 ecu to the 03? as the 02 it has all fields is there an thing to check or change?
Sorry - posted into the wrong post!
Moved my post to here: https://www.evolutionm.net/forums/ecuflash/636700-flashing-airtrek-turbo-22.html#post11839331
Airtrek Turbo 2005 latest Def XML file
Dear all,
I'm planning to reflash my airtrek turbo 05 and who or whr to obtain the latest Def xml file from? I don't mind to contribute for paying in return for the latest xml file ya.
Thanks in adv.
Warm Rgds Tomtom
My email adds is tomtom8118@yahoo.co.uk
The definition for 80700010 (Airtrek) is the best and comes with the latest version of ecuflash pretty well defined. If you have a different ROM ID then i suggest changing your cars to 8070010.
You can also use 89970009 (GTA) which also comes very well defined with Ecuflash. But to use that you need to change the MAF scaling, injector size and geearbox shifiting is set different.
Airtrek 5AT Boost spikes on gear changes
Airtrek 5 A/T upgrade to mac 3 port boost solenoid, 3rd gear at wide-open throttle and tune it, it reaches the target boost of 1.3 bar, but there are boost spikes to 1.7 bar The wastegate duty cycle runs between 80-100% on gear changes. Are there any solutions?) using Gregs XML (89970010) Sh7055 mitsukernel.
crypto
Lancer Engine Management / Tuning Forums
Oct 4, 2007 06:47 AM
