Timing Belt Advice
Timing Belt Advice
So cam install went awry last night. Could not get one of the cam gears back on as the belts slack had tightened up and it was impossible to align the dowel and the bolt hole for the exhaust or intake cam.
Anyway, timing belt will come off tonight. My timing belt has <30,000 kms on it (so like 20k miles). I am hoping that I can just set the crank pulley to tdc, remove the timing belt, put both these cam gears back on, set them to tdc, double check oil pump alignment, and put it all back together.
I shouldn't have to **** with the balancer belt right? I am not doing this to replace anything, just reset. I have a t belt tensioning tool and all the needed tools. My timing experience with 4G63 motors is a 1997 Eclipse GST.
Other than the balance belt removal steps is there anything in this guide I can skip over? https://www.evolutionm.net/forums/evo-how-tos-installations/467552-how-timing-belt-balancer-shaft-belt-accessory-belt-replacement.html
Keep trying.
If you remove t belt you dont need to remove or time the balance shafts unless you remove the belt. But there is 1 balance shaft that needs to be timed.
It can be timed on the mark but the counter weight is off time.
The way you do it is.
Set the balance shaft on the mark and if it wants to rotate on its own its wrong. You shoulf spin it 180 degrees then.
Spin the balance shaft slowly let it spin to the timing mark on its own then you know its timed correct.
If its set on the mark and you notice it wants to spin forward you need to rotate it 180 degrees. Hope this makes sense.
Keep trying.
Sounds like you didn't use the tool that holds the tensioner compressed.
Keep trying.
Thanks for the tip and the video regarding timing the balancing shaft. I plan on just leaving the timing belt on the crank sprocket. Just need to get the top loose and the tensioner out so I can get the cam gears properly.
Just a huge bummer, it had gone super smooth up to that point, a big part of that being my friend who helped me had previously done the install on his own vehicle.
I've done this a couple of times and I just pulled the belt. But, whatever short cut you wish to employ, figure it could go awry and have the engine at top dead center, the timing marks lined up and have painted marks on the belt and onto all the sprockets. Then the worst you've got is a simple timing belt job.
I also always just remove the belt.
But for leaving the belt on, I would imagine you need to leave the valvecover off so you can get wrenches on the cams so you can rotate them into position.
Also, man, that water pump pulley is a way bigger ***** to get at than it was on my Eclipse!
