Best SD rom for USDM evo 9
Old Jul 22, 2017, 03:09 AM
mines5's Avatar
Hi guys..
I want to know which is the best SD rom for USDM evo 9
with complete tables of ISCV disassembly and Idle tables.
- The rom available in SD 2.0 thread doesnt have different map sensor scalings as in other evo 8 roms.
- Target Idle tables
Any explanation for this ?
Old Jul 22, 2017, 06:40 AM
4b11slayer's Avatar
9653 works for all
And 9417 supposedly is more defined
Old Jul 22, 2017, 10:06 AM
mines5's Avatar
Originally Posted by 4b11slayer
9653 works for all
USDM Evo 9 my friend ?
Old Jul 23, 2017, 04:05 AM
Evo9_Dubai's Avatar
8859?
Old Jul 23, 2017, 07:59 AM
mines5's Avatar
Yep 8859- so after alot of searching and help from a few friends I made the xml updated.
There were a few incorrect addresses and scalings.
Old Jul 24, 2017, 10:55 AM
TrendSetter's Avatar
ive been using 3d sd on 8859 for almost two years now. works fine. ive had to do a lot of work to the xml to make it all right.
Old Jul 24, 2017, 11:25 AM
mines5's Avatar
EXACTLY ! i have spent hours to get the correct tables and add new ones to the xml.
I cant find the Post Cranking Enrichment tables and MAF compensation tables for this rom.
Interested to know how you adjusted the cold start ..
Old Jul 25, 2017, 12:45 AM
Evo9_Dubai's Avatar
I've added a few things to my 8859.
- Fan control (its hot as hell during summer)
- startup fuel
- fuel pump control
- wideband o2 for CL instead of oem oxygen sensor (needs testing)
Old Jul 25, 2017, 02:00 AM
mines5's Avatar
- startup fuel
- fuel pump control
Can you share these tables ?
- startup fuel
Old Jul 25, 2017, 02:12 AM
mines5's Avatar
Damn --- I totally forgot -
Mfred just found some fuel tables for 8895-
Evo9_dubai : were talking about the same tables from Mfred's thread ?
Old Jul 25, 2017, 05:23 AM
i added the wideband closed loop tables from mrfred but i never ended up using that rom. i have had really good luck running full open loop.
my startup fuel took a long time and a broken starter to get right. i have lsx coils that are extremely hot so i had to reduce dwell and fuel to keep it from kicking back. its still a little finicky starting once in a while but its a race car, right?
Old Jul 25, 2017, 09:22 AM
Klaiceps's Avatar
Curious about your lsx coils. Are you running a CDI along with the lsx coils or is it just a straight COP setup without CDI?
Old Jul 25, 2017, 11:09 AM
ls truck coils (D585) are smart coils, you cant run cdi with them.
they are extremely hot coils, so much so that they erode the electrodes off iridium plugs and i have to periodically reset the gap.
the stock ecm can control them directly, if you make a harness to adapt to the stock wiring they work fine, you just need to lower your dwell tables appropriately.
from http://www.megamanual.com/seq/coils.htm
On the LS1 coil there is around 40 milliamps of peak secondary current with 5 milliseconds of dwell time. On the LS2/truck coil (AC Delco D585), there is 120 milliamps!
Klaiceps (Jul 25, 2017)
Old Jul 25, 2017, 11:18 AM
mines5's Avatar
Can you share your Start up Fuel settings ?
How are your cold starts ?
Old Jul 25, 2017, 02:38 PM
Klaiceps's Avatar
Thanks for the info. Do you have any pictures of how you mounted your coils?
Quick Reply: Best SD rom for USDM evo 9
