Oil leak....help!
Old Jul 23, 2017, 09:48 AM
X2jesse1x's Avatar
Oil leak....help!
I moved my car out of the garage today and noticed oil on the ground. So I jacked the car up and saw oil sprayed all over the underside. I'm assuming it's coming from a pressurized hose or fitting. Can anyone tell me where it is leaking from?
Old Jul 23, 2017, 01:27 PM
c08
c08's Avatar
Are you sure that's not grease leaking somewhere from the rubber boot in the pic?
Old Jul 23, 2017, 02:05 PM
Jp7
Jp7's Avatar
do you use mud-w30 oil?
six40 (Jul 25, 2017)
Old Jul 23, 2017, 02:09 PM
RazorLab's Avatar
If that is oil from your motor or trans/t-case you have other problems...
I'd bet your CV boot is compromised.
Old Jul 23, 2017, 02:39 PM
X2jesse1x's Avatar
Well it looks like oil on the ground but grease in the pics, so I have no idea. Lol
Old Jul 23, 2017, 02:55 PM
4b11slayer's Avatar
Thats def cv joint grease i see. Clean,repair and re inspect.
Old Jul 23, 2017, 05:42 PM
X2jesse1x's Avatar
Yeah it's definitely the passenger side inner cv joint. However I have an oil leak from the oil drain plug, I ordered a few crush washers so hopefully that will take care of that.
Old Jul 24, 2017, 03:46 PM
Jp7
Jp7's Avatar
you guys didn't like my joke.... "mud-w30" lol.
Old Jul 25, 2017, 05:49 AM
X2jesse1x's Avatar
lol I got it, i was just to worried to laugh at the time.
Old Jul 25, 2017, 09:20 AM
I see this a lot on the X's, more so than the 8/9's. You can get a boot kit and have a driveline shop replace the boot. I would do both axles, the other is like leaking too. And if it isn't, it will be soon. If you buy the crimp pliers, they're fairly easy to rebuild yourself. Here is the boot kit you need. You'll need two to do both axles.
https://www.lancershop.com/customer/...productid=3989
Old Jul 25, 2017, 09:51 AM
six40's Avatar
Yeah that looks like CV grease. I mean, it's not uncommon at all for these to leak Could be as simple as needing a new clamp. If not, you need a clamp/boot kit. I changed all my clamps on the front axles over the winter when I had it all apart. All of mine were leaking.
Old Jul 25, 2017, 10:31 AM
X2jesse1x's Avatar
how can I tell if it needs replaced or if I just need new clamps?
Old Jul 25, 2017, 10:36 AM
six40's Avatar
If the boot doesn't show any weather cracking, rips, tears, etc or if it's not hard and brittle. Clean it up well all the way around and inspect it!
4G63_EVO
Feb 9, 2014 08:30 AM
EvoIXMR
Sep 12, 2008 09:02 PM
elphalba
Mar 15, 2008 11:34 AM
tysonK
Nov 5, 2006 04:01 PM
Blacksheepdj
Lancer Troubleshooting
Mar 31, 2005 08:44 AM
Quick Reply: Oil leak....help!
