2011 GSR- MHI-18k- 100k mile stock block
Recent VD- 2 years and about 30k miles on this setup/ tune. 111,000 miles on my stock block and counting. Posting for anyone concerned with longevity on higher mile 4b11's.
Mods on the car
MHI TF06-18k (ported)
AMS widemouth downpipe
AMS Intake
ETS UICP
ETS V2 3" exhaust
Ultimate Racing test pipe with muffler
Depo 4" IC
Synapse DV
Grimmspeed EBCS
AGP catch can
AEM 320 LPH
ID 1000cc
CC Stage 2 "street" disc
E85 fuel
Tuned by Chris Carbee
*edited with 3rd gear run to 8k.
Last edited by sik_z33; Aug 29, 2017 at 09:44 PM. Reason: Edited with new (better) dyno
I have never checked the compression, I checked for boost leaks a year ago. Yes original timing chain, the motor has not been touched throttle body to manifold.
You should start checking compression to watch for changes and consult with Evo specialist about timing chain replacement. I heard the stock chain can stretch from fatigue and enough to mess up motors with boltons. I don't recall which years this happens more often with.
Mitsubishi revised the timing chain design and oiling mechanism for 2011+ models, my local shop said it's only an issue for 08-10 models and recommends changing timing chains on those models regardless of mileage on the motors.
The following 2 users liked this post by sik_z33:
2006EvoIXer (Jul 27, 2017),
Topher919 (May 12, 2018)
Should upgrading the oil lines when getting the mhi even be considered? And I wonder how much of a difference it is with a ported mhi vs non ported , if ordered from fp that upgrade is about 95$ which I find worth it. But any e ways nice setup I bet much like it Alot
When I was upgrading my turbo I wanted the upgraded line because apparently it's really easy to crack the factory line if you are not careful. My shop (AG auto) advised me that it was not necessary so I reused the stock feed and have not had any issues.
Regarding ported vs non, mine was ported by my shop not FP. There is a little lip on the hotside exit that is eliminated once its ported, I opted to have it done for that reason.
I have not. Interesting... I may test it just to see how the motor is internally. Was your car displaying any symptoms of change like loss in power etc? My car honestly feels the same so I have never seen the need to test is.
Leak down changes over time in any engine lol. If the car runs well, doesn't smoke, etc, I wouldn't bother with it.
ugakirk (Nov 9, 2020)
Do ARP rod bolts also, if they stretch and boost is increased, potential boom. Chains where updated in 2012, double stacked instead of single stacked links, less wear and stretch.
