Engine rebuild
Engine rebuild
Hey, haven't got an evo but i am currently looking into buying one. But the thing that worries me is when and how do i know when it's time for an engine rebuild??
Model i am currently interested in Evo 8 FQ-340 MR
This will be my daily (Hopefully)
You can have a qualified shop perform a compression test and a leak down test to verify the condition of the top end. And you could do an oil analysis to see fi the engine is making any metal indicative of excess wear.
TurboAlex (Jul 27, 2017)
Hey, thanks for the fast reply, sorry if my question is dumb :P
Seen a lot of ppl do rebuilds at 150K-200K
Actually u can also buy a compression tester and test it yourself.. its quite simple..
check youtube on how to do a compression test on an evo.
tons of videos are up
Between this and your fuel pressure tirade, it's getting very old.
There are people on this forum that have been working on, building and tuning these cars for over two decades with a great wealth of actual knowledge. Stop muddying the waters with your half baked posts.
sketchi (Jul 29, 2017)
Im running strong on e85 and 500+ hp for 4 years now. 150k here. No issues.
You can usually tell the condition of a engine by.
1.looking for sludge build up.
Looking in the oil cap and looking at the cylinder head. If its nice and silver its been maintained. If its black or bronzing it hasnt gotten very well maintained oil wise.
2. Compression test.
I believe the spec is 150 psi. If they are near 7% of spec or each other the engine shall be considered healthy.
If they are below spec. Youd follow up with a cylinder leak down test and see were the loss of compression is going. I.e piston rings,valves,head gasket. Etc etc.
If you dont gave anything good to say go find another forum.
We dont need false info spread cause alot of the people on here dont know alot and might take your b.s and take it serious.
Try changing your user name and start over man.
Thanks guys! I know a garage who specializes in Re-building evo engines and are very well known.
Norris Designs their name, and are only 10 mins away from me. But i probs won't be going with big power in the evo, 400 or 420 will be more than enough for me on and off track!
