Oil in cylinder
Oil in cylinder
I've recently rebuilt my motor. Pretty much every is new except for the block and the head itself (valves, springs and retainers etc all new) but im getting oil in cylinder 4 (furthest right) Any ideas on what could cause it? I've thought that maybe I didnt run it in properly but then id expect all 4 cylinders to exhibit a similar issue.
Im starting to freak out because its cost me quite a bit (Pricing in Australia for this stuff is messed up!)
Cheers
Cheers
Fresh built about 10000km on it. I’m genuinely not sure. I don’t know too much about the internals and stuff of an engine this the asking for help. Was wondering if there’s any quick checks I can do rather than just going straight to ripping the motor out again.
A quick check - how about the dip stick? How much oil is it using? You should know having driven it 10000km. If no oil is disappearing from the crankcase then nothing is wrong.
This is all great info! At least now I have a better understanding of what could be wrong. I’m also crapping myself because if it’s rings then I’ve paid a whole lot of money for what amounts to nothing
You're not going to fix it without pulling it all apart.
When you pull it apart, you'll find out what's wrong.
You'll also find out that the tests you've done to find it out, they don't work.
Often with a new engine that's smoked from day one, it was honed wrong.
Maybe not though?
Maybe the ring gap is wrong?
Maybe piston to bore clearance is wrong?
Maybe insufficient clearance from top of valve guide to retainer , too much cam lift?
But if it's only a problem with cylinder 4?
That one runs leanest, gets more air, detonates first and most.
You didn't mention the max boost that it's had?
Maybe not though?
