Help identifying wire harness/wires
My radio hasn't worked since I got the car, so I've been trying everything I can think of to find the issue. I think I got it narrowed down to the amp, however while I was looking under the dash I noticed a semi melted wire harness and several cut wires. The harness is located on the drivers side firewall, under the dash, near the carpet.
Does anyone know what this harness is used for? I also noticed a spot that looks like it's for a harness, however this harness isn't long enough to plug into it.
I thought so to, however if you look at the black box. The wire harness connected to it is white and this one is thicker and black. I think it's to thick and won't plug into it. Plus the wires are far to short.
Did you ever figure this out? I have the exact same harness/connector and I am not sure it plugs into it. Although my harness has a solid white part, not sure how it could connect.
the harness doesn't have enough slack to go up to the module. I also have no cel lights on for anything.
gobigny
Apr 16, 2014 10:09 AM
Senvae
Dec 22, 2013 12:25 PM
prowakeskater
Jun 5, 2011 06:31 PM
