2.0 6466 evo 9
2.0 6466 evo 9
Just installed infinity on the car and made some pulls.
9 to 1 2.0
Manley turbo tuff rods
Wiesco hd pistons
Gsc s3 cams
Stock ports on the head
Curt brown ported skunk 2 intake manifold
Full blown throttle body
Shearer fab standard placement turbo kit
6466 t3 .82
Ts comp tune twin pump with -8 feed and -6 return.
2150 injectors
E85
Built trans and t case
Triple disc
Sorry if I left anything out.
Car is on 40 psi
Imw’s mustang dyno
9 to 1 2.0
Wiesco hd pistons
Gsc s3 cams
6466 t3 .82
2150 injectors
E85
Triple disc
Car is on 40 psi
Imw’s mustang dyno
Nice. I am building a 2.3.
Mild porting
Solid lifters
With a 6466 .84 t4 flange divided
I am trying to figure out what the 6466 with a .84 rear is rated at,
Does anyone know what size rear housing precision rates their turbos?
Mild porting
Solid lifters
As stated above you're going to at least want a 1.15ar hot side.
Dakota Evo (Jan 20, 2018)
I choose .84 to keep it streetable. Rather sacrifice a bit on top and get a better punch, it's a four Cylinder bro. I asked a different question regarding the rated hp of that turbo with that rear housing. Has anyone tried the 6466 with a .84 rear and what was the result ?
Originally Posted by Sheriff
I will have to wait till after the dyno to be sure to be sure. What did your combo make ?
Sorry for the thread derail OP.
dude that's is fkn insane. 600 plus kw. How much do you think I would loose running the .84? I would be jumping over the moon with the cat the fiddle and the silver spoon if I made 550 kw at all four
And thanks. English Racing did a great job on the motor and tune. The owner is super happy with it.
