New upgrades, no car won't start
I just finished installing a Walbro 255 and new FP Green. I also had an oil leak from the camshaft seals that I fixed during the install. Now, I am attempting to start the car and it will not start and idle unless I put my foot on the throttle. If I remove my foot, the car will almost immediately stall out. It will crank over endlessly, fuel pumping whining in the back, but will not start unless I put my foot on the throttle. When it does actually start, the car almost sounds like it is misfiring, like a Subaru. I originally got a code for the TPS, which I knew was going out, so I replaced that and the code is gone, but the car still won't idle or run well. Any one have any ideas on what to check? Thanks
did you mess with the Cam angle sensor at all?
Did you remove the black single wire thingy on the fuel pump hangar? If so when installed you might have made the oring go in crooked. Will cause your concern. Also maybe bad timing and bent valves.
Same thing happened to me when i worked on my friends evo X..
I installed a gtx garret stock frame, an AEM fuel pump, and set of injectors. It started and ran for about 2-3 seconds then died and would not start.
i found when i put the sock on the fuel pump, i did not latch the clips in place. After a made sure the clips were all on, i put everything back together and she started right up.
I would go back and check all connections, electrical and mechanical. It is possible for something to fail not related to the upgrades but that would be a big coincidence.
so I just reinstalled the stock pump and nothing changed. car will not idle, and it will only run with the throttle. I've been back over everything I touched during my install and even the stuff I didn't touch...
Unless I am installing the pump incorrectly, I don't think this is the issue anymore. And this isn't the first fuel pump I've installed(not on this car, mind you), and they've all gone in without issue before
Check your iac. Also did you reinstall the coil packs in the right place? Also are you on speed density? If so find a working map sensor and install that. See if that changes anything.
On your cam angle sensor did you install the disruptor shield correctly inside the cam housing? That will cause fuel cut and miss fire. Same with a crank angle sensor. Car will start but cause a lot of problems. ...like sounding like a Subaru.
Coil packs were installed the same way they were taken out. Still on stock MAF, so no SD. I didn't touch either of the cam sensors or the crank sensor other than unplugging them. I did check the connections again, and they're all fine. I will check again of course
is your FPR stock? is the vacuum line hooked up correct? is the return line pinched? pull the return line and see if it is clogged, maybe the tank side of the return line got messed up when you had the pump out.
Photos of plugs?
Oil on no 4 will be a broken piston.
There's obviously more than just one fault, the most serious being oil on no 4 which will make it misfire
